- Dec 3, 2010
- 1,038
- 951
- 0
Downloadin now nick. Lets see what its got..
Just make sure you follow the directions on the OP to avoid problems. If you do encounter errors don't hesitate to ask me.
I'm having the issue with not being able to load widgets. I'm also unable to access the settings. I followed the instructions exactly as you have them.
Is there a need to wipe dalvik cache after each flash or after 1.3?
Just wipe it once after you get v1.3 fully booted.
Everything's working great now, thank you.
No dice. Force-closes and still no preferences...
hey Nick, im currently trying the Thunder Rom. Can i just flash nRom over it? should I go from 1.2 then 1.3? or just go to 1.3? Thanks.
I was on ThundeRom when I flashed nROM. You should flash 1.2 then 1.3 otherwise you may run into the same issues I did.
Starting with 1.2, then moving up to 1.3 worked for me.
Question, is there a framework.apk that will work for the rom, that will work with the ultimate on-line theme kitchen?
Any chance of getting a circle battery icon set to the black notification bar with the gingerbread icons?
