Can you download weather bug and see if you can get a lock?
I use weather bug elite and I got a lock within a few seconds, normal time. Download and install GPS Status from market, open and it will download a GPS assistance, that seems to help.
On my EVO and CM7, you needed to do a ## code on a stock rom in order to get gps working on the CM7 Rom. The code reset the gps and that is the only way to get working gps on the EVO and CM7.
Is there anything like that for the Optimus? I had my wifes phone by window for 10 minutes and it wouldn't lock. Just keeps flashing. I am going to try and test it when we go out and maybe it has something to do with my location, although I have never head a problem get gps signal in my house.
Great rom and thanks for the work, but if I cannot get GPS working, will need to downgrade her to a Froyo Rom which I really don't want to do....Hopefully I can get GPS to work.
Do the same, GPS Status from market, open app, let it download the assistance. If that doesnt work, wipe cache, dalvik cache, flash the system debug, then reinstall rom. Did you make sure Use GPS in checked in setting?
Menu, Settings, Location & Security, Use GPS Satellites=Checked.
