Come to think of it, that could be why I never had issues. I have my settings backed up with Titanium backup and I believe that includes the privacy settings (or at least, I haven't fiddled with them recently) and I did wipe everything every time I installed a new nightly (including running the debug system format zip) so thinking that's probably it![]()
Not sure if a titanium restore of apps would restore these settings as well, but possible? Who knows..
Also, for those of you who were talking about poor battery life, I think I've found the answer. I was being plagued by extremely poor battery life as well - I could literally watch the percentage drop, and it would only last about 10 hrs or so at the max. I looked around and found an old tip of making sure your radio is set to CDMA auto. Apparently, it can sometimes get set to GSM auto, which results in the radio almost constantly searching for signal, even though it is still connected to CMDA signal, and this shows up as an extremely high Time Without Signal (TWS %). Mine was crazy high - at least 60% on a regular basis, sometimes as high as 80% or more.. Anyway, here's how to fix it:
- Open up the dialpad, and type:
*#*#4636#*#*
(the numbers are for 'info'; don't press call, it should automatically go to a 'Testing' menu)
- Go into 'Phone information'
- Press Menu, and select 'Select radio band' (this will result in a force close, but that's what we want.. just keep going.)
- Go back into 'Phone information' and scroll down to the bottom'. It will probably still say 'CDMA auto (PRL)', but the problem is this is probably a visual glitch. Or it might say 'Unknown'. Either way, switch it to something else, then switch it back to 'CDMA auto (PRL)'. Then you can turn off the radio and turn it back on with the button right underneath that.
- At this point, the fix has been applied, but it would be a good idea to clear the battery stats to get a fresh start. So boot into recovery and do that, then reboot. The fix *should* stick after this reboot, but I think it didn't when I first did it. But assuming it does, then you're golden. It will be like this for all other reboots. If it does not, then just do it again. You can tell if it worked if when you go into battery usage, and go into cell standby, the TWS% is much lower. I charged mine completely overnight after applying this fix and have been off the charger now for over a half hour and TWS% is still at 0% (even though cell standby is at 46% (but that's not a problem at all..), and my battery is still at 100%. Before, by this point, it would probably already have dropped 5% with the same amount I've been using it.
I'm pretty hopeful to get my usual 1.5-2 days' worth of battery life out of this phone now, but will update if this isn't the case..
