ARCHIVED: [DEAD ROM]The Scott Pilgrim ROM (CM7 Gingerbread, Zefie Edition)
Status
Not open for further replies.
I got a random issue that I've never had with this rom. The phone process does a force close when im in a phone call. It doesnt drop the call it just closes the app. this happened when i flashed the lastest build from 4032011. i did the gapps and the debug thing when i flashed it so if anyone has a suggestions please reply.
Same here. Just started hitting home button instead of back......
I guess I need to retrain myself, huh?
yeah:) took me a few days...(have had the issue since the 04012011 update.......)
I seen I think it was on r/android/ people complaining about this. It seems to be a google voice issue and not a rom issue. although I have seen a couple other apps do the double open but on close it doesnt reopen.
Now onto my most recent WTF moment.
I updated to the 04112011 update. Shortly after updating I switched to wifi to sync isyncr-wifi up with some new music. Well I never turned 3g back on. Over night I forgot to plug the phone in and the battery died. When I plugged it in to charge it and the phone powered on data stayed off and so did wifi. I toggled airplane thinking it was that ******ed bug. In still was off so I pushed the data widget and up she came. I unplugged the phone and shut it off. waited a minute or so and turned it on. And the same thing happened. data is switched off. Push the button and it comes on. No biggie I can handle that.
Ill prolly reflash later but wantd to put it out there.
TL;DR? Data is not restarting after reboots.
is anyone having an issue with their mobile network? I flashed the latest build and I can't connect to my network. Also, I'm missing the market. HELP
I'm on nROM now because I needed bluetooth, but I had this problem on nROM as well. To solve it:
Get a root file explorer. nROM comes with ES file explorer, so download that if you want. For ES at least, go into settings, Root settings, and check both boxes, (use HAIPK).
Then go into /system/app, and double click on the "vending" apk, which will reinstall market from /system/app.
Not sure if this'll work on CM7. Worked for me on nROM. Should also work if maps won't install right after a flash.
I hope this is not a noob or question that has been asked previously...
Love love love this ROM...blazing fast compared to the last ROM I had installed. Very happy, very satisfied. Thank you for all your hard work!!
I did have one question...and believe me, I've searched and played with it but cant figure it out. How do I get to preferences so I can change my launcher to my LauncherPro that I previously bought? Normally when I press Menu, theres a preferences button to click, now I only see Settings.
Uninstall then reinstall llp. Then press home and choose your default launcher
Swyped from my Gingerbread'ed Optimus S
Status
wokulbo1
