ARCHIVED: [DEAD ROM]The Scott Pilgrim ROM (CM7 Gingerbread, Zefie Edition)
Status
Not open for further replies.
So my phone was doing some odd things, so I went back to stock wiped data and reloaded 4/11 from scratch after doing this the toggle buttons on the status bar drop down are gone and I can't figure out how to get them back.
Any idea's???
Sent from my CM7ed LS670 using Tapatalk
Any idea's???
Wipe again. Data, cache, dalvik and flash the formatsystem.zip. then reflash the 4/11. See if that works.
Sent by Tapatalk ----- Optimus s
Uhggg I was hoping to avoid doing that, finding 2 hours do do that lately has been a pain... well guess ill give it a try when I get to it.
I know its a pain but a complete fresh flash is the way to go. Especially with this Rom. The only other thing you could try would be to wipe cache and dalvik and reflash the 4/11. But I don't think it will work because as zefie stated early on, without a complete wipe including the formatsystem.zip flash, there is data leftover on the phone that needs to be gone for this Rom to function properly.
Also for the future, get titanium backup. Its a life saver for restoring apps and data after a clean wipe.
Any idea's???
I just reboot. Works every time. And I have to do it everytime I flash new update. The last few at least.
Any idea's???
Well that sure beats a full wipe and reflash. LOL!!!
Any idea's???
Well for **** sake, a reboot worked, should have done that before asking thank m8
Any idea's???
when in doubt...reboot lol
also you can sometimes go into CM settings and untoggle the notification widget then retoggle it back on....
Any idea's???
you could install an app called "notification restart" it restarts the notification bar, no need to reboot.
i run this sometimes when i change themes, because some times the notification bar doesn't update properly
So, a total n00b ? and off topic, but since you mentioned Titanium Backup up there, I'll ask here, I know, I should search. Is there a way to restore you apps with Titanium without hitting Installl and OK on each and every one. Even with a batch restore I have to confirm every app.
The Pro/donate version does not make you confirm each install. It's worth it.
Reactions: j37hr0
No (unless you have pro), but it only takes an hour lol.
(I have 70 apps)
Swyped from my Gingerbread'ed Optimus S
Does this work with the lg optimus V ??
It should work. The only problem you will see that I can think of is that your menu and home keys will be reversed. I know a couple of Optimus V users who have used this rom on their phones. Always do a nandroid backup to be safe though. That way if something isn't right you can easily restore. You can get a key remapper to change the keys if you decide to.
Reactions: fr0zenblood75
I see , and is there any special steps i should do or can i just do it as it says on the first post ?
Yes you should be just fine following the steps in the op. Like I said, if you run into troubles you can always restore to your current setup as long as you do a backup.
yea i just flashed it had a few glitches with the market but its fine now but i noticed when I flashed the system format zip at the end it said installation aborted is that dangerous ??
Status
trixie909
