ARCHIVED: [DEAD ROM]The Scott Pilgrim ROM (CM7 Gingerbread, Zefie Edition)
Status
Not open for further replies.
A mechanical engineer, an electrical engineer, a scientist and an IT guy are car pooling to work when their car breaks down.
The mech. Eng. Says "I think I heard something break in the motor. I'm going to disassemble it and take a look."
The elect. Eng. Says "I think its the alternator. I'm going to test and rebuild it."
The scientist says "I think the fuel is bad. I'm going to test the molecules."
The IT guy says "I think if we all get out of the car and get back in, it will work."
Sent by Tapatalk ----- Optimus s
I'm not quite clear on this bit, but do you need to clear cache/data and format system when flashing a newer version of this ROM (I.E. coming from 04042011 nightly to the 04112011 nightly)? Or should I be alright just flashing the new nightly by itself? Thanks.
I believe it's best to wipe cache ......no need to format....
Maybe in the 50s and 60s :P
Nowadays its more like... IT Guy: "I think it is the ECM. I'm going to reprogram it." :P
I think Im having GPS issues with this rom on a Optimus V
There is no official Optimus V support. I don't have one and have no reason to get Virgin Mobile being locked in contract with Sprint.
I pitched the idea of a fundraiser for me to buy an Optimus V with minimal service. I pitched it on Twitter but as I expected it was a stupid idea no one would be interested in :P
Oh thats cool man I really cant complain this Rom is great thanks ! :D
Plex Media Server
So I have a question about cm7 I have 2 optimus s one with cm7 and one with the original sprint build on it I can play movies through the one that hasnt been moded and it works great but the one that has been moded it will play the audio for the movie but there is no picture is there anything in cm7 that needs to be modified so the video will work or did any of the video option change in cm7. Thanks if you can help and thanks if you can. I love CM7 and the work that has gone into it.
Thanks
Meg
Thanks
Meg
I would also like to know more about this. I know since Google put out gingerbread, they changed the way Android handles video (don't know the technical stuff), but I have had some issues with Orb, Plex and Crackle not working. I'm sure that's just incompatibilities with 2.3. But I haven't tried playing any local video files yet.
Meg, not that I can help, but it might help someone else help you if you told us what file type/codec you were trying to play? I would expect an mp4 file compressed with h.264 should work fine, but as I said, I haven't tried this yet.
Also, 1 more thought... Some manufacturers add in their own support for other video formats - My samsung moment used to have divx support stock, but it's not a feature (i don't think) build into Android. CM7 being a molded to our phone from another phone's files could be why certain file support isn't the same from stock to CM7.
The funny thing is the phone that hasn't been modded works great despite the file type and codex used it is just the one that has cm7 that is having the issue.
To my understanding and correct me if I'm wrong but pled is useing my comp to stream the video to my phone so it doesn't matter the codex or file type.
Its something to do with stagefreight, our phones hardware and orb I think. Disabling stagefreight lets orb work but cm7 needs stagefreight to run so you are hosed.
Sent from my phone...excuse the spelling mistakrs.
the divx codec does not work in cm7. im not sure why, it could be a licensing issue.
as for streaming i dont know what you are using but it may be using divx since it is lighter on the cpu. not sure if you could switch it to h264.
Reactions: fenderman
so has anyone tested this on a vortex/vs660? roommate just got one today, and there isn't much support or difference from the optimus s, i know the menu and home buttons are reversed, and i think i remember seeing a key cartographer somewhere that i'll look for later.
being as its cdma and basically the same phone, i don't see why not, except the buttons you already know about...
Status
mattellis99
