I was wondering if anyone is having the same issue of the baseband reverting back to v8 after updating to v9 on stock and then flashing this rom? any suggestions?
didn't even notice but youre right baseband version LS670MV8_6038
but SW version LS670V9
I can confirm this too. I also was on 2.2.1 before I flashed.
It looks like the baseband is coded into the ROM (by LG/Sprint) rather than reading the true baseband from the radio (how HTC does it). This means we could change it to say "IFxingRock" and that's what your baseband would show as. If you had the V9 radio, you have the v9 radio. You cant flash radio's currently with these phones so it's not possible for us to provide a different baseband, just different words to show in the baseband field.
Right now it is not possible for any developer to improve or reduce your phones ability to communicate with towers. These are controlled by radios/PRL/ and PRI. These cannot currently be flashed so no developer can improve or reduce your signal. What you have is what you have. Period.
It's a display issue that's not worth spending any time on because if we change it to v9 then people with v8 will think they just got a radio and if we leave it at v8 people with v9 will think they lost a radio. We're damned if we do and damned if we don't so IMHO it's simply not worth investing any time.
Cheers!
EDIT - Just wanted to mention that in the future
maybe we can look into having it read properly from the radio but again, since it's just a display issue, it's not going to be above things like flash 10.1, apps2sd, our own kernel (so we can comfortably let you guys OC) all of which are actively being worked.
EDIT # 2 -were currently chasing down a crazy theory on this. Hope to have an update later. We'll let yah know
EDIT #3 - Confirmed, LG hard coded the baseband to read whatever they want. If you have the radio.img from the V9 update your absolutely fine.
