ARCHIVED: Drew's CM7 builds (stable: 08/09/2011 | experimental: 08/08/2011)
Status
Not open for further replies.
Is anyone finding that this rom is not quite as smooth as previous versions?
Sent from my LG-LS670 using Tapatalk
Re: Drew's CM7 builds (stable: 08/02/2011 | experimental: 08/06/2
I do not understand why I am running into issues trying to move apps to SD. I keep getting not enough space when I have 4GB+ free?
I have noticed this as well
I guess overall, I have not noticed any performance difference. But I have also not used .05ex quite as much. I am also running the battery tweak, data2ext, and have very few apps installed right now (just the ones I use regularly) so it boots quicker.
There is always the possibility there is some sort of conflict with an app you are running, or a conflict with your settings in general. Did you dirty-flash or re-flash?
No I haven't yet, I'm going to dirty flash now. Thanks, that didn't even cross my mind to do that lol.
Sent from my Optimus S CM7
On the browser when you go to Facebook and hit search there is a glitchy thing of white bars can anybody else confirm this.........
Flashed using updater. Ended up going back a version. It was driving me nuts lol
IV bin noticing alot of my apps that I have deleted r back an apps that I have installed r not there any more an wen I reinstall them it think it is still there an tells me that it will be replace anyone have any ideas what's going on
Did you dirty flash from stable to experimental or vice versa?
sent from my Cyanogen Optimus
when I ran the update, it restored some apps i got rid of (fm radio) and had to uninstall it again
I'm running 7.1.0.1.5 with the Collin_ph battery tweak and Data2Ext4 with a 1GB partition and I'm noticing no additional issues with this rom over the previous experimental build.
I downloaded the update using the OTA updater however, since I read the Data2Ext issue on page one I dirty-flashed it from recovery followed by the Data2Ext file and the battery tweak. Doing that, I didn't have to restore any applications at all and my phone is running just like it was before the update.
It is a google sync thing you can tell it to sync what apps are installed then if you wipe your phone, when you sign back into google your phone will download and install what you had on there previously.
Sent from my Drew-CM7ed LS-670
Drew quick question for you, is there a way to disable the home keys turning on the screen, I ran reborn for a while and I really liked that only the power button turned on the screen, thanks in advance.
To anyone questioning battery life:
10h 6m 14s on battery, 81%.
Keep in mind, ive had very light use today. I had a cub scout car wash for four hours and only checked weather and STL cardinals stats a fews times each. I'm having no problems with battery life on this rom. I love it. I am using stable 001.
Loving the OTA update system and I think a lot of folks really appreciate not being nagged about updates but I personally wish there was some type of notification. Any chance of making that a selectable option or something drew? I really am not much of a coder, so I understand if it is more difficult than I am making it out to be.
Status
Hopluikla
