ARCHIVED: Drew's CM7 builds (stable: 08/09/2011 | experimental: 08/08/2011)
Status
Not open for further replies.
Re: Drew's CM7 builds (stable: 08/02/2011 | experimental: 08/08/2
BUG REPORT:
Build ID: STABLE-001
TuneIn radio reports "internal decoder error" when trying to play internet streaming radio.
Telemike, I am using tunein a lot on the same rom and I don't think that's a bug. I've had it on other roms as well, it's probably a tunein/stream error.
Tune in is working on mine running stable 001. This is on Wifi, I'll try 3G later
BUG REPORT:
Tune in radio works fine here, use it every day with Bluetooth audio over 3g.
sent from my CM7 gingerbread Optimus S
I've been holding off updating my phone with the experimental builds, so I can't wait to see what the stable build brings!
Out of curiosity how long does it take to compile?
Sent from my Drew-CM7ed LS-670
He said it earlier in this thread, I believe it was 4 hours or so then he has to upload it.
Depends on the day. Lol my computer is all over the map when it comes to CM7 build time. Sometimes 1.5 hours, sometimes 4 hours. Usually about 2-2.5 hours. Also have to add in upload time which is also all over the map.
I biffed 2 minor things in the first compile today but they're fixed up now. Uploading.
Reactions: Guppy
Re: Drew's CM7 builds (stable: 08/09/2011 | experimental: 08/08/2
The link to the build doesn't seem to be working, just send me to the main forum page.
Edit: nevermind, it works now...
Thanks!
Build Release:
7.1.0.2 (today's stable build) has been released. Check the front page for the details.
Would the Drew-002 Build to the latest stable count as Stable to Stable or would you recommend a wipe?
All builds in the DREW-XXX line are considered experimental. Do a full wipe.
Working now, had the same problem yesterday. When the URL of your link doesn't contain "http://" at the beginning it makes dumb things happen.
Reactions: ColdRush
Downloading now, thanks drew.
HINT: You do not have to do a full wipe if you are updating within build types (e.g experimental to experimental or stable to stable). If you are switching between stable and experimental (or vice versa) a full wipe is required.
It's funny, everytime my market auto updates to that new ugly one, I end up updating or installing a ROM. :p
awesome build, but I may the only person here that MMS still does not work. When I send a picture message it only says "sending..." but never really sends it and when I do receive a message, I click on "download" and it says "downloading..." without it really downloading anything
Also, Im coming from Stable-001 to Stable-002
Status
WarrMads
