ARCHIVED: Drew's CM7 builds (stable: 08/09/2011 | experimental: 08/08/2011)
Status
Not open for further replies.
Re: Drew's CM7 builds (stable: 08/09/2011 | experimental: 08/08/2
Thanks Drew. It's running like a dream.
I would like to make a request, that on of you guys that are 24 he's plus battery life out of your phone do a write up on all the settings and programs you use to make this happen?
Thanks in advance!
And drew I am loving this Rom!!! Especially since Bluetooth is working in it.
Sent from my Drew-CM7ed LS-670
If you flashed the file for Netflix or edited your build.prop. lol. Happened to me a while back.
Proof: http://forums.androidcentral.com/lg...ildprop-edit-netflix-screenshot-included.html
i didn't ever try that out....wanted netflix but didn't want to deal with all the stuff that went with it for something id probably only use twice
i did edit my build prop one time i was trying to make the carrier label say sprint sucks but didn't edit the right line and then lost interest
Thanks in advance!
All the basic stuff: http://www.androidcentral.com/keeping-your-charge-how-improve-battery-life-your-android-phone
And flash in recovery: http://db.tt/G5Og7Xa
Reactions: Guppy and Kamron
a great rom
but i need some help
ok see i have lost all use of my phone
because my data is off
i have juice defender and set cpu
so could some1 tell me if there's a setting for rom data (on/off)
a great rom
Airplane mode?
I thought about messing with that and changing the label, but I found that it also screws up the sprint apps. I like my nascar app...
Sent from my LG-LS670 using Tapatalk
Thanks in advance!
Id like to 2nd that request. Regardless of what anyone says I ran the same apps and settings on drew's and zefies and my battery life is far better on zefies so I would be interested in knowing any tweaks people are doing cause I gotta be missing something. @bakethis I read that article weeks ago and it helped a little but there wasn't much I didn't already know @ that time. Also I didn't even overclock when I ran drew's rom as the rom was responsive enough as is. I overclock on zefies maybe 10 mins out the day. When I spent 10hrs rooting this bad boy back in early may with Jondevere he told me overclocking isn't necessary 100% of time so I never got in the habit of doing it so I know that wasn't what drained me so fast.
I'm posting this again just in case you missed it dizzle. ;) That file and that guide are about all you can do. I regularly get 24+ hours out of mine. Emphasis on the file!
Also, charge to 100, go into custom recovery, advanced and clear battery stats. Then don't charge it till the phone dies. That will help make the battery life more accurate. Make sure its at 100% before clearing it though or it could cause some issues. ;)
Now that battery stat tip I didn't know about and will try thanks for that bakethis. Buy let me ask about the Collin_Ph_battery tweak because that I did flash before but I do have set CPU even though I removed profiles after flashing before. Now let me ask, I'm one of those people that doesn't do anything to my phone without doing a days worth of research and when I looked @ the battery tweak thread they said its not for the faint of heart. And I haven't used my terminal emulator since I got root. So my question is if I flash do I need to set profiles and stuff on terminal em b/c I would say I'm comfortable enough to go messing around in terminal emulator or do I just flash it and let it do what it does. Also I know set CPU will be screwy but would I need to uninstall it? Also does it really work? LOL sorry for that last question but I'm kind of a straight to the point person. That's for enlightening me. Let me also say I flased battery tweak about 2 days before flashing drew's rom about 2 weeks ago. When I decided to go back to zefies I did a restore and lost battery tweak so I'm using set CPU at this moment
Sorry but one last thing just to be clear LOL. You say charge to 100% go into recovery, clear battery stats and don't charge again until it dies?
Love the rom! OTA updates are amazing, only problem ive noticed is that when checking for rom updates, if i rotate my phone it cancels the check. Running ex-006
Actually, the default profile is what I have run since KYSmith ported it to our phone and it's been great! Make sure to uninstall anything that controls the cpu first, ie SetCPU. In this ROM we have the option to control cpu settings in the cyanogenmod settings under performance. Make sure that you uncheck the 'set on boot' before flashing the tweak in recovery. :)
Also, the terminal emulator interface is quite user friendly for this tweak (if you choose to modify). AND, you can easily see that it is working by doing the following: (after flashing and rebooting) -go into cyanogenmod settings > performance > cpu settings. note the current cpu speed in mhz. -plug in charger and again go into cyanogenmod settings > performance > cpu settings and note the new cpu speed in mhz! :D You will notice it will fluctuate with the difference in power supply, usage, etc... It actually works great. I used to experience lag while running an app that would control the cpu based on the same variables. But, running this script causes no lag or undesired results. (it is speculated that the script causes an issue with a certain app while using it with Drew's CM7, but we'll see if you notice ;) I don't want to give it away because it probably won't effect you :))
Thanks for the Info. I might reflash everything tonight (drew's rom, battery tweak) because I'm s.p. is starting to lag today for some reason. I only have one signal bar and web pages are taking forever to load
What's I'm s.p.?
Any word if the mic will be fixed when the headset is plugged in?
Drew, you had mentioned a couple weeks ago that you had been tinkering with the ability to use the handset microphone during phone calls while wired headphones are plugged in to the device. You had mentioned being hopeful that this issue would be fixed pretty soon. I wanted to ask if there has been any progress on alleviating this issue.
[To give you a time reference of when we discussed this on this thread: It was the day you were debuting the release of the ROM update which included the in-ROM PRL update tool]
I cannot thank you enough for all your hard work on this awesome ROM.
Thanks, in advance, for updating us on this issue.
Edit, for subsequent readers:
The problem was a change in GV/Sprint integration, not CM7: Google Voice Blog: Google Voice and Sprint integration is live
Hello all. Just flashed the most recent stable ROM to a Sprint Optimus S this evening and have run into a problem. Followed all instructions, everything flashed fine, but the phone is now using only the Google Voice # associated with the Google Account. I can't seem to find any way to get the phone to use the native Sprint phone #. Have I missed something? Even uninstalling Google Voice, all calls are coming from the associated GV#. I've checked the online account, nothing has changed from when it was stock LG ROM. There must be a setting somewhere that I'm boneheadedly missing, right? I'm not a dev, or even a big techie, but I can follow instructions, have rooted & flashed ROMs before, and to my knowledge didn't change any settings here to cause this. Please help!
eta: Disconnecting the phone from voice.google.com has restored the original #, so I'll reinstall Voice on the phone, then re-link everything, and I imagine it will be fine.
edit#2: so in reinstalling gVoice to the phone, I only get two options: "Use my existing Google Voice number" (all calls/texts will display GV#) or "Use this phone's number" (will replace my GV#). In setting up GV on a stock ROM, there is always a 3rd option, to choose which # to use. We need to use the original Sprint #, but still want the GV# forwarding to the phone--I don't want to replace one with the other. Am I doing something wrong, or is this a "feature" or limitation of using CM7 on the Optimus S?
Do you have a nandroid of the stock ROM still? Make a nandroid backup of your current state, then try switching back to stock and check to see whether you can receive calls on your Sprint number from the stock ROM. While you're on stock, maybe update your data profile (I think it's settings > about phone > update profile).
The idea is to see whether this is an issue on Sprint's side or with this ROM. If you can get the Sprint number working on the stock nandroid version, then switch back to the last nandroid that you just made and see if the phone number works.
Reactions: theBIG
Yes, I made a nandroid backup, but had not restored yet. My first assumption being that I made some boneheaded error.
I can get the Sprint # working in CM7, however, after having disconnected it from gVoice from my PC. Soon as I install gVoice back to the phone, however, it's only giving me the two options to use only the GV#, or to replace the GV# with the Sprint#. This leads me to think it's not a Sprint issue--should I still go through restoring the stock nandroid to confirm? (also, if it matters, I did update profile and PRL prior to nandroid backup and wiping.)
I've got the whole family using GV for voicemail only/as a second incoming line, so missing that third option has me really puzzled.
eta: fully restored stock ROM nandroid, everything works fine with calling, GV, voicemail, etc. No issues whatsoever--exactly as it was since we set up the phone 8mos ago. I'm at a loss. I assume there must be other people out there who've flashed CM7 to their Optimus S without going all-or-nothing on GV, so it has to be something I'm doing, right? :confused:
What about if you reactivate GV on the website rather than through installing GV app? Then instal the GV app after you've got GV set up the way you like through google.com/voice
Reactions: theBIG
Status
Franci
