ARCHIVED: Drew's CM7 builds (stable: 08/09/2011 | experimental: 08/08/2011)
Status
Not open for further replies.
Re: Drew's CM7 builds (stable: 08/09/2011 | experimental: 08/08/2
I thought the new kernel was included. Does it need to be flashed separately?
Sent from my LG-LS670 using Tapatalk
Nope. Dont think its included yet. Flash it separately. :)
He just updated the Kernal yesterday but the rom is from 8-9-11 so of course it doesnt have the new kernal
First post here. I successfully got this ROM up and running and have worked out most of the kinks except one main one that is still bugging me...
Any apps that have a constant icon and info in the notification bar/dropdown, such as a weather app for example, have started shutting down after a couple hours in CM7. I'm assuming this must have something to do with the way that CM7 manages apps, but it is rather inconvenient to have to keep opening my weather app to get the notification back.
Is this a known issue? Any fixes?
Thanks!
-Adam
Stable 002 has the older version of the kernel then. Gotcha. Hadn't realized yet that there was an update for it now. I'll update that then
Thanks!
-Adam
Look into my FAQ. There is a file in post 2 question/answer 2. It pertains to you. You should follow the instructions I have listed even though it says its for a different issue. It should clear everything up for you.
So I should download the Debug-FormatSYSTEM.zip, do a backup of my current setup, wipe everything, flash the debug file, and then flash back to my original setup?
Thanks!
-Adam
Are any of these apps moved to the SD card? If so move them to the phones internal storage.
Reactions: reltm
Don't use backup/restore options from recovery. You need to start fresh so you will wipe everything then flash again. I have the steps listed in my FAQ. You can use titanium backup to backup apps if you like but nothing more or you will reproduce the same issue. It's actually recommended that you download all the apps from market again.
Reactions: reltm
I've had the same issue, but only with Beautiful Widgets. It's the only program I have that updates notifications each hour for weather. I didn't format/reflash the ROM, but simply adding a widget made the weather updates keep happening as they should. I had notifications turned on but no active widget before that. It's been fine ever since. Just my experience if that helps at all. :)
I had a lot of issues even restoring with TB.
What I found worked best is do new app download from market of whatever source
Then restore data only from TB. But do data restore only on apps you need to.
Game saves, bookmarks,etc
I've also found this to be the best way to do it. It takes more time and effort up front but saves a lot of headaches in the long run.
Not that anyone really knows me....or that my thanks means more than anyone elses...but i just have to say thank you very much for this awesome work. Thank you Drew and Crew. Great Rom. Im enjoying it very much.
Id also like to state that ive tried others, and appreciate them just as much. I've learned alot the past few weeks and continue to learn more and more. Maybe someday i will be abe to contribute to what seems to be a great community. ;)
Smile everyone...Don't let life getcha down.
P.S. I added a lil sumthin sumthin for the Cyanogen walls! Enjoy.
Reactions: pergerson6
Just wanted to say thanks drew for the sediment Rom sadly I must leave the LG optimus . I have purchased a HTC EVO 4G so I Will move on too rooting it . But wanted to say thank you for your hard work on the aswome roms and I will miss them. Thanks
Sent from my HTC EVO 4G Tapatalk
I'll come back to this rom as soon as a retouched theme with Lloyd is ready. XDA themes for cm7 are lame
ya i agree i have not found any that r good or worth paying for.
has anyone got the themes to work on the phone iv tried to install them both an nothing changes
Themes don't determine my decision on ROMs. I don't really theme mine. I theme my wife's though. And she has Reborn. :cool:
I thought there was plenty of downloadable themes in the market for this? Am I mistaken?
There are plenty if everyone looks hard enough.
sent from my Cyanogen Optimus
I am using mixer. I installed it through the apk given in this thread http://forums.androidcentral.com/lg-optimus-s-rooting-roms-hacks/99999-cm7-mixer-theme-issue.html and enabled it through theme chooser.
To see how it looks like, go here: [CM7 Theme Engine][HDPI/MDPI] Mixer Theme..Updated 7/26/11..Now with Purple/Red. - xda-developers
edit: oh I see that you were talking about some specific themes. I ll just let it be here, just in case someone's interested.
ps1. 1000th post in this thread.
ps2: battery life with stable 2 is amazing.
Status
mamunursk9988
