ARCHIVED: Drew's CM7 builds (stable: 08/09/2011 | experimental: 08/08/2011)
Status
Not open for further replies.
Re: Drew's CM7 builds (stable: 08/09/2011 | experimental: 08/08/2
I still hav problems with it... fc's keyboard reset and contacts dont sync, like fackbook and myyearbook and twitter :( kinda dissapointing but good work so far!!!
CM7.1.0.2 with XioniaRedux 07272011 is me...
Wondering about having different notifications between text, email, etc...is that possible?
For now, text, gmail, and email all have the same notification. I thought that could be changed, maybe I'm missing it?
thank you I have been waiting on a CM7 build for this phone not just a port everything works and its 2.3.3 thank you the last port I tryed everything worked but the blutooth I got to have my headset
I only flashed an hour ago and all ready I love the rom again thank you :D
It's 2.3.4
sent from my CM7/Reborn w/ 1 Gb internal storage Optimus S
Always happy to help, hit that thanks button if I did
that build has issues. random reboots being the major one.
Hey guys, I just got the 2.3.3 update and am a little bit unhappy with it and the bugs that have come up after updating. Someone recommended that I try rooting and installing CM7. I found a good guide to root my phone, but will installing Drew's CM7 build still work? Thank you!
Saddly no there is a post that explains how to get the VD back (Lol) cause there is only the one rom that works with the new radio.
Sent from my LG-LS670 using Tapatalk
I used the KP500 utility to revert back to ZVD a few times until I could get the root to work to update to ZVH. All seemed to work just fine.
Is there a guide on how to revert it back? My phone won't even charge if it isn't plugged in to the computer, hahaha, ugh.
NO, there is. Look for the thread Revert to V9 by sfhub. If you scroll down, there are instructions on replacing the same steps with ones needed for VD. Even the cab files are attached. I used the same method to come back from VH to VD and it works flawlessly.
Awesome, thank you. Do those instructions translate to OS X?
I dont own a Mac. So, can't really say. Read through that thread by sfhub and see if there are instructions for Mac in case they are different. Or ask him directly, I'm sure he will guide you to the right place.
Did anyone see my question about having custom notification sounds for text, then a different one for email..instead of 1 notif for all?
I called myself searching everywhere for this, but could only find the Notification sound, which includes text, email, and gmail.
I don't know if I'm getting a Gmail, email, or txt message when I hear the Notification tone....
I know that using third party apps will allow you to do this. I don't think you can do this natively.
Status
RangelS25
