ARCHIVED: Drew's CM7 builds (stable: 08/09/2011 | experimental: 08/08/2011)
Status
Not open for further replies.
Re: Drew's CM7 builds (stable: 08/09/2011 | experimental: 08/08/2
okay i did what you said and reflashed the rom... I cleared out everything and after i finished the install checked the gps and PERFECT!!! everything is great and that was my problem the whole time. Thanks guys its nice to get real help from people instead of getting flamed in here. Love this website and the people here rock thanks a lot. :)
what are you guys opinion on overclocking? Is there any issues with it if i do? Also if i do overclock, do i need a diff kernel?
Good to hear! Make sure to hit the thanks or like button for someone. That's what keeps us going. ;)
Every phone reacts differently. Every phone is usually good to 748. Some are able to get stable results above 800. But, it depends on the particular phone so you will need to try it yourself (don't select the 'set on boot' feature until you find a stable frequency). I am able to go up to the highest setting on my phone. :)
EDIT: Also, you don't need a different kernel...
I flashed Drew's CM7 stable build but bluetooth headset is not recognized and cannot be paired. Does anyone have the same issue? Is this a known issue? Any suggestion is greatly appreciated!!!!
Try going to recovery and wiping everything again then flash the debug zip, then flash the rom... Should clear up any issues...
I tried wiping everything again and flash debug and rom....my optimus is still not finding my Bluetooth headset....I have the plantronics m100 headset....and it worked before I rooted and flashed the rom...I have no idea why its not working...seems like I'm the only one with this issue? Anything that I may have missed?
Can you try a different bluetooth headset? A friends maybe?
Any word on a software update? Or is kernel.org still nixing the possibility. Or are you thinking of jumping to the new radio? Your last build still runs great, I have just been jonesing to use your ota updater!!
Sent from my LG-LS670 using Tapatalk
I searched, but didn't see it...
does this rom require you to be running the zvd radio? or does it work with zvh?
now I feel stupid, but how do people seem to be getting connectivity? I have nothing.
This only works with ZVD radio. If you put this on the ZVH you will not get any connection.
sent from my CM7/Reborn w/ 1 Gb internal storage Optimus S
Always happy to help, hit that thanks button if I did
Yes we know about that build.
He was talking about a update to the ZVD CM7 build. So it is not confirmed!
anyone else having issues with billing market apps to your sprint account with this ROM ive juyst noticed any paid app wont work if you try to pay with sprint wondering if its just me or maybe the ROM itself
Had same issue! I used my credit card and it was fine.
ok so its not just me then there might be a issue with the ROM and Sprint servers for billing?
I've got an issue with your current stable release, I lose the ability to install apps on the phone. For instance, I want to restore an app using Titanium, when the Install/Cancel screen shows, I'm unable to click the install button. When I touch it, nothing happens, I can only hit the cancel button. Now I've re flashed your mod again, and it happened again, takes about a day for it to start acting up. I'm unable to figure a cause, and I searched the forums, and came up empty. Please help, I want to install apps on my phone.
You're talking about two separate things here. Titanium Backup restores apps, not installs. If you're trying to restore a Froyo app, it probably won't work and even if it did could cause problems. Re-download apps from the Market directly.
I have not had any problems with buying apps and paying with sprint on this rom.
Did you set it up correctly with sprint?
yeah its all set up right ive billed to my sprint all the time but since switching to your ROM i have not been able to bill to sprint and ive checked with sprint to see if i had any blocks put on my phone and theres not so im going to switch to a different CM& build and see if it works if not then idk :)
I've been having some issues for a few days now. I have been running the latest stable build for about a month now. A few days ago as I was updating a couple of applications the phone restarted unexpectedly. It then continued to start up, followed by restarting until I pulled the battery out. I could get it to run for a while after pulling the battery out, but it wasn't performing like it should have. I put it on the charger overnight, and woke up to it completely overheating, and it had what I call "the fuzz" on the screen (think back to old tube tv's without a signal). It hadn't charged, and instead it had drained the battery. I got it to work somewhat for the rest of the day and then I reinstalled the ROM. It worked just fine for about a day, and just a few minutes ago it suddenly restarted again and I wasn't downloading anything or using the internet at all. Now none of the SD card applications will load. I'm not sure what to do at this point. It is working for basic things like calling and texting, and at the moment it isn't rebooting.
Any help would be appreciated!
(by the way, I love this ROM when it works)
Status
RangelS25
