ARCHIVED: Drew's CM7 builds (stable: 08/09/2011 | experimental: 08/08/2011)
Status
Not open for further replies.
Re: Drew's CM7 builds (stable: 08/09/2011 | experimental: 08/08/2
No Cm7 for Zvh baseband. Team Hydro an into issues trying to port it. Look for the HydroRom coming soon instead.
hello i a few ?s and this may seem confuzeing to most when i installed CM7 i had to baseband verison weard right know moveing a head tryed out another rom reborn rom off the get go had a baseband verison ls670mvd_60401001 know ? is why in some of these roms there is no baseband and shuld i worry at all i dont a factory restore on my phone when i did the custem recover from xionia cwma v1.2518.6 know i should of backed up from factory but at the time i didnt know what i was doing but i got part of it right know this u all of u posting im userstand it more but i also seen were i can force flash the baseband but still why is it working on one rom and not the others is that just part of it or what im kinda confuzed how one is working ad the other is working also but no basebands
im rewrighting this because i messed it up so please forgive me starting over hello i a few ?s and this may seem confuzeing to most when i installed CM7 i had no baseband verison weard right know moveing ahead tryed out another rom reborn rom off the get go had a baseband verison ls670mvd_60401001 ok ? is why in some of these roms there is no baseband and should i worry at all i dont a factory restore on my phone when i did the custem recover from xionia cwma v1.2518.6 know i should of backed up from factory but at the time i didnt know what i was doing but i got part of it right know this u all of u posting im under standing it more but. i also seen were i can force flash the baseband but still why is it working on one rom and not the others is that just part of it or what im kinda confuzed how one is working and the others isnt working and post back on how i can force my base band back on or something simple i cant read that well i know ur not going to fix ur hole post but for one perison but i dont like takieng a nother hit in the nut like i did from the begineing not backing up the stock sprint rom do hicky also whats the easy way to go back to factory to i knwo i have to have the stock recover and updater zip than i have to root and all that good stuff to use the and also with cm7 im havieng av voice mail problem to idk if thats due to the base band or what but when i did the reborn rom it was gone
I'm not sure if I understood everything you tried to say. As far as the Baseband "UNKNOWN" thingy is concerned, there is no need to worry about it. I'm sure you are on ZVD baseband. You can fearlessly run Drew's ROM. Don't worry if it says unknown, it still works. I would personally suggest thekraven's CM7 as its more upto date and you will see your baseband version too :)
hey i installed the stable build of your cm7, and i cant get any cell service! pleasseeee help
Most likely because you flashed it while on the zvh baseband. Nand back to a zvh based rom (gRom, optiRom, yourMomRom or stock zvh rooted) and service will return. If you want cm7, you have to revert to the zvd baseband. I would recommend thekraven's cm7 as itis still being developed.
The left hemisphere of my brain just went on strike. And one of my eyeballs exploded. My wife is standing next to me in a vaporlock.
OMG i got my phone roooted and now im just really iffy on flashing rom... i dont wanna wipe my . any one got a play by play they can help me out with? - 2.3.3. rooted. i really wanna expand my phones internal memory, free wifi hot spot? (sprint)
O fyi my baseband is LS670Mvh but my software is LS670Zvh?
Then you want to look at "your mom's rom", opti-rom, grom or eventually hydo rom. Just make sure the rom you choose is for ZVH. (LIKE THE ONE'S I LISTED)
sent from my CM7/Reborn w/ 1 Gb internal storage Optimus S
Always happy to help, hit that thanks button if I did
Running this rom... (yea, havent updated since august...) phone is ridiculous when trying to get connected to USB - freezes and resets about 97.4% of the time, and is running sluggish after MONTHS with no issue... thinking of just flashing a new rom but any suggestions for what could be be causing this?
btw, even getting it to charge half the time is a pain
The rom is on hold hopefully. This was around the time CM was released for these phones[I think]…
thekraven has some very good and up to date builds if you don't mind flashing a new ROM....
^^^ i agree, thekraken has some rather nice builds. I used them for quiet a while. Personally if your going to spend the time upgrading why not try the new Hydro build?
Status
RangelS25
