droid x stuck in bootloop, RSD won't recognize.
DON'T hit the search key. That doesn't work anymore.
2. when you see the triangle hold down both volume buttons
3. select wipe data/factory reset ---press power button to select
4, reboot system
thanks for that... soooooooooooooooo much thanks
i also have this problem. I get into recovery and wipe data/reset and have rebooted same loop. Can't get rsd lite to show phone. when I try to load update from zip it fails signiture. Any suggestions.
Be sure to put the phone in bootloader if trying to sbf, then make sure that in RSD Lite that "administrator" is checked off. Check the other post on RSD not recognizing the phone.
4, reboot system
I joined this forum for the sole purpose of thanking you for the above post. You have no idea how much you've helped me. I'll continue to browse through the wealth of knowledge that's here. Hopefully, I can return the favor one day. I'm still new at this :D
marik999
