E: failed to mount /efs (invalid argument)
Yes Odin completed successfully but im going to try the REAL stock ROM now. I will let you know as soon as I finish
Hi there,
I have the same problem I think. When I turn on my Galaxy S3 it does not boot past the Samsung Logo. I have pulled the battery on several occasions. This does not work.
I then try to boot into the recovery console and have a few options that dont resolve my issue. However in the recovery mode I see the error "E: failed to mount /efs (invalid argument)"
I have put the phone into download mode and tried the firmware upgrade and initialsation and I get a message saying this device cannot be updated.
Any ideas ?
Welcome to the forums!
Sounds like you must have a GT-i9300 - apparently Kies doesn't handle this feature like it does on other models.
You can try using a tool called Odin (just Google it - look for v3.07; find a source on XDA) to reload the firmware, which you can find here - mouse-over the region codes to find your country/carrier and download the latest version.
I don't remember if the firmware overwrites the /efs partition, so if that doesn't fix the problem you may have to try something like http://forum.xda-developers.com/gal...ol-updated-08-12-13-efs-professional-t1308546 - I haven't used it myself so I can't provide any support but I'm sure you can find help over on XDA.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk
Many thanks for this reply. I can however access the SD card from the Recovery Console. Is there a file I can download to run the recovery from the SD card ?
I don't think any of the files I pointed out will load using the stock recovery software.
You may be able to find one in your device-specific sub-forum, but you're really better off using Odin.
Or you could try a local carrier store.
Hi there,
Any ideas ?
Hi there,
i have identical problem to you.
Did you find a solution?
Hi there,
I have tried to download the stock firmware but it times out. I try another mirror and I get redirected to a page that seems to be just prompting me to download spam. Is there any advice you can give me to work around this ?
Also when I do download the stock firmware is there a guide as to how I use ODIN ?
Welcome to the forums!Sounds like you must have a GT-i9300 - apparently Kies doesn't handle this feature like it does on other models.
I don't remember if the firmware overwrites the /efs partition, so if that doesn't fix the problem you may have to try something like [TOOL] Updated! 26/06/14 - EFS Professional v2.1.73 - Also for NON-Samsung devices! - xda-developers - I haven't used it myself so I can't provide any support but I'm sure you can find help over on XDA.
You can look on SamMobile.com - you'll have to register to be able to download though.
You can find instructions here.
Hello everyone,
I have a similar problem. My phone GT-I9300 is stuck on the boot procedure, and then it continousliy reboots.
If I enter the recovery menu it says: failed to mount /efs (invalid argument)
I never installed other firmware on my phone.. therefore I am surprised that this happened..
I followed different posts on this problem.. many of which suggested to use KIES to install a fimware update.. however KIES does not work in my case..it says: this version cannot be updated!
Then I used ODIN3 to flash a stock firmware obtained from samsung-updates
I still get the same problem..
the phone gets stuck while booting if I install: firmware version 4.3 (2013)
it continously reboots if I install firmware version 4.1.2 (august 2013)
it continously reboots (and there is now way to turn it off except removing battery) with firmware 4.1.1 (october 2012)
I still have 1 year warrenty.. I hope.. so I'll try to bring it to the repair shop. Unless you guys have a better idea?
Thanks!
Unfortunately, flashing firmware does not touch the /efs partition. If your phone is still under warranty then your best bet is to take it in for service - a Samsung Service Centre should be able to nuke the whole system and rewrite everything.
I have same problem like "failed to mount /efs" flashing stock rom cant solve problem.
my fault only that did not backed it up.so I m going to servicer center. I learned lesson by this that before doing anything like flash new rom u should atleast back up yout efs. cause u can get stock rom from website but not efs settting that is unique for every android phone.:p
Im getting the same error and my phone isnt connecting to the pc it just there connecting and nothing happening. I got the error message saying to restart the device. Im really lost at this point.
As noted in post #51 there's not a user solution for this problem - reloading the firmware will not correct a corrupted /efs partition. Your best bet is to take it to a Samsung Service Centre (or someplace like Best Buy) to see if they can nuke the whole system and rewrite everything correctly.
Hi! I am having the same problem with my GT-I9300 S3 phone. I already restore back the stock firmware but the phone stucked at SAMSUNG logo and blue light is ON. Please help! Thank you.
Hello and welcome to the forums!
You're having which 'same' problem - the /efs error during boot, or the phone getting stuck during the boot?
Did you use Odin to reload the stock firmware? If so, do you have a copy of the log?
Have you tried wiping the system cache in Recovery mode?
I have same problem on galaxy y and i download samsung kies 3 but my device is not able to connect with compuer please hep me
I tried using the second option on Kies tools and put in the model and IMEI. Kies said that initializing is not supported on that device. Does that mean I need to take it to best buy? Thanks
Hi there! I tried to follow ur instructions but unfortunately, my device can't seem to connect to kies. Do you know why? I hope you can help me as I have the same problem. Thank you so much.
I am having this same issue and have tried the steps above. Everything works until it tries to load the files onto my phone and I get an error message saying:
The PC Failed to recognise the mobile phone.
Any suggestions on how to get past this?
Lassi876
