EB01 Accurate Battery with charging icons UPDATED
Unfortunately, I had trouble making sense of the instructions in that thread. Wasn't sure about too much stuff to try to ask without feeling like a total incompetent loser that doesn't deserve to be helped, do unfortunately, I'll have to wait until the flashable 2.5 version is put out.
The only stupid question is the one that isn't asked, and if anyone around here tells you otherwise, send me their way. ;)
Just sayin' :)
Ok, chris. Can't take it anymore. I'm asking... first off... Are aren't of these steps on the sumpter? I would say a few are, only because I don't know how to unzip on my phone. That question will start me out. Thanks again, chris.
And while I'm asking about what the phone can do, since superclean, what do you guys use for word docs since think free has been removed? I knew that's random, but they were tied together in my mind at least.
So, anyone try this with superclean 2.6 yet? I'm wondering if it will work...
Maybe I'll try and report back, but I won't know how to fix it if my phone breaks.
So... A in unzipping the file one the computer and putting my phone in clockwork and the same time? And if so, that does mean the phone its disconnected from the computer during all of this. I'm sorry. Just having a little bit of trouble understanding the instructions and what to use. Thanks for a little more detail if you could provide any.
Ok, so is the file run on the computer our the phone? Thanks for the time, man.
I assume you're talking about the BatteryModder? The file is run on your computer. You have to boot into CWM and plug your phone into your computer, mount the /system directory (you do this in the Mounts and Storage section of CWM) and then run the BatteryModder from your computer.
Reactions: Brettdacosta
The program is very easy to use, very automated. Just make sure you downloaded java into your computer before you start
Sent from my SCH-I500 using Tapatalk
corneliarphillipis
