Everything You Need To Know To Un-"Cripple" Your Captivate
lol...frodian slip...lol
Okay... that's what I thought, so i stopped and asked before I tried your thread....
Your link for 'superoneclick 1.7' doesn't seem to be working....
Oy vey lol I'll look into it,
Its fixed....
looks like it starts to work properly....
then..
same error as it tries to update from sdcard...
can't verify 'E signature'
Its fixed....
then..
I should have explained further...you unzip the file and run SuperOneClick from your computer.
oh...lol... I had the 'other way' programed into my brain... DOH....
Wow... that was too simple.
(FYI, don't mess with the name of the zip file.... like rename it 'update'...lol)
not sure if this is where i should be posting but heres my problem...ok really needing some help with my samsung captivate, I did a super one click root on my phone worked out great then i downloaded animod from applanet and it worked well till i had to restart to get the change to fully switch and well it would run through the boot all the way to the point you should see your lock screen instead it was black and vibrating every two min or so tried odin3 and i get as far as file analysis and it never moves...if anyone can help id be greatful...sorry so long
If its only gotten that far, pull the battery and try again.
Sent from my SGH-I897 using Tapatalk
"adb push %userprofile%\desktop\settings.db /sdcard"
I was able to pull the file settings.db to my desktop. When I try to push back to my phone after changing the default value from 0 to 1 using SQLite Manager I keep getting this error.
c:\Program Files\Android\android-sdk\platform-tools>adb push %userprofile%\desktop\settings.db /sdcard
failed to copy 'C:\Users\Michael\desktop\settings.db' to '/sdcard': Is a directory
Can someone tell me if I need to change it to /mnt/sdcard? That's where I see a file called settings.db and settings.db.backup.
It appears that the app "titanium backup" allows you to delete, un-install, restore,freeze individual apps. Is this the same as doing all those command prompt actions except a whole lot easier for some of us. Is there a difference? Seems like it would save alot of headaches as there are many posts in this thread looking for certain app commands to delete them?
Can anyone answer this?
su says permission denied!
I followed all the steps to root the phone, and I have busybox and superuser permissions installed. The busybox installer also confirmed that my phone is rooted.
Then enter adb shell and type su, and it tells me "Permission denied"! What am I doing wrong?
okay so im having a problem on the part that says cp/dbdata/databases...etc and what happens is it says it's not found +i have root su and sdk also busybox v1.19 from busybox installer
pls someone help i'm getting sad over here
this method is so complicated. why would anyone want to use it. After you root your phone just install a custom rom and ta-da, problems solved.
hey i have a dell aero(i know its a terrible mistake) on 2.1 update 1. it is unlocked(no at&t) . i cant install 3rd party apps. there is no option for usb debugging or unofficial sources app installing. all i want is 3rd pary app installing, and moving apps to sd at least.plz help.
here i a link of update
http://opensource.dell.com/releases/aero/2.1/
i'm actually new to cmd, i could not do anything after Connect USB to phone with USB Debugging ON
Command prompt... is there any other way without typing commands? please help
Judging the date on some of these responses I'm praying i get a response.
I am currently trying to Root my Samsung Galaxy S (Captivate).
I've gone through every step, but i can't seem to access the internal memory on the device.
I dragged and dropped the .zip file to numerous locations throughout the device to try and get it too work, but thus far, I have come to nothing. If at all possible to anyone reading this, could you explain what to do from this step forward, as well as how and where to drop the zip file, I would more than greatly appreciate it.:)
