evo 3d freeze/reboot on half or less battery power, good on charg
cinciner
I bought this phone on ebay. didn't check initially, now passed return period...
When on charger it performs perfectly. but when on battery especially when the battery power is less than about 50%, it begins to give problems, like death of sleep, freeezing, or reboot.
I tried to fix by all different methods, changed battery, factory reset, flashed different ROMs and kernels, blow mainboard using hot gun...
but the problem is still there... am desperate... any help will be appreciated..
Re: evo 3d freeze/reboot on half or less battery power, good on c
Blow mainboard using hot gun?
Does the device over heat when its running, and say plugged in but in sleep mode?
Try charging to %100 and wipe the battery stats, its worth a try
no overheating. tried wipe battery, didn't work...
i recently found even the battery is pretty full, it will reboot or freeze.
If you think its a battery issue I would just try a new battery. Sounds stupid but just might do the trick!
Did you ever find a solution to this problem? My situation is exactly like yours, bought the Evo 3d on ebay and later found the rebooting problem. I would really like for there to be a solution.
aaronr
