Galaxy S5 won't charge. Plug it in to charge. Battery flashes on then disappears continuously. What should I do?
dononymous
Overheated and bought a new battery. Came at 12%. Phone boots but when I plug it in to charge it, lightening bolt never appears.
Shut the phone down and plug it in to charge it. The battery with the lightening bolt appears on the screen, with no percentage, then disappears. This happens repeatedly and battery never charges.
I have:
1) Cleaned the ports
2) Factory reset
3) Tried a different cable
4) Tried booting in safe mode (won't charge)
5) Left the phone for an hour (it just did the same thing... battery appears, disappears the whole time)
Any help would be greatly appreciated.
Don:(
A damaged USB port connector, or damage to its internal circuitry?
Re: Galaxy S5 won't charge. Plug it in to charge. Battery flashes on then disappears continuously.
Most likely a problem that happened such as you pulled out the cables a weird way or from an angle and messed up a circuit
Posted via Samsung Galaxy S5 model SM-G900A running 5.1.1 AT&T
Marabishi
