[GB][2.11.605.0][Sense3.0]BAMF Forever 1.0.7
Re: [GB][2.11.605.0][Sense3.0]BAMF Forever 1.0.5
why was the app drawer changed to transparent??? it's so hard to see!
Hence the 25635425522 variants of the app drawer in the first post. Something for everyone....
Re: [GB][2.11.605.0][Sense3.0]BAMF Forever 1.0.4
MyTouch 4G allows users to change from 5 to 7, but required a wipe of data to do it with it's stock ROM... I had one for a couple months before I picked up the Thunderbolt.
Ok maybe I should have word it differently, there isn't any Thunderbolt roms with Sense that allows this option..
I am blind in one eye and I love the transparent launcher and hoping the status pull down will be added soon.... If you dont like it you can download the non transparent update in first post and flash it, simple solution..
No error at all. Sync is successful and no errors
When I go to the lockscreen...it just reads the no forecast available BS
Sent using Tapatalk
Enable the GPS feature, this build doesn't seem to work without this on, I also usually have to open Google maps before it updates.
UPDATE: Fix for Hotspot doesn't work but one I posted still works and also the Hotspot status has issue also in 1.0.3, Version 1.0.2 stated that "Hotspot was active" but the latest build says "Unable to connect to Wifi"... If you add the files from the attached patch this should give you a working version with the correct status notification.
1.0.2 Version
attachment.php
1.0.3 Version
Is there any update on changing this back, after 1.0.2. the notification for Hotspot has been reading incorrect notification?
Sure. Give me time though. I can't always fix things within minutes. Thanks for the pic so I know what it is supposed to say, btw. Saves me time.
No problem, i understand but was just wondering... Thanks for the work.. Also just so you know the Hotspot app still lockup when ran unless I use the installation that I posted on the first page
Now here is a mod that I really like... and it's a mod that the OP has on the first post for download... 5x5 app drawer:
Thanks for the screenshot, that does look nice! I've used some 5 column app drawer mods on some ROMs that look like crap (text misaligned and such). I may have to load this up!
Any word on why this build would start a never ending reboot cycle?
Never did I see that on any other build/rom.
Honestly, I've run pretty much every version of this ROM and have never had a reboot once, let alone a cycle of them. Nor have I seen any other posts either here are over at the BAMF forums (which is getting close to a 200+ page thread) with these issues. Some device "freeze ups" yes, but not reboot frenzies.
My guess is you something on your device may have gotten corrupted, I'd suggest doing a full re-install (w/ wipe, naturally) and giving it another go.
I couldn't find the 2x8 app drawer with checkered background that I wanted so badly!....
(Just kidding).
Seriously though, the 5x5 is awesome. Icon size, spacing, and text is perfect.
anyone else getting rather terrible battery life. I unplug the phone at 100% and 5 minutes later I am at 90-94% without turning on the screen or anything. No emails received, no texts, no calls.
What can I do?
What can I do?
The phone quits charging when it reaches 100% and sometimes doesn't resume charging when the battery has discharged some of it's power. The phone shows that sudden drop in charge, but in reality it's been using battery power for a little while already, the battery meter is just catching up. How about you unplug the phone for about 3 minutes or so and then plug it back up? Maybe at the beginning of your day, or something like that if you really need that 4-5% ( I'm not poking at you, I need every drop as well).
it's not really that it is compensating for the battery drop after it stops charging, It drops fast from any level. Much worse than the stock GB leak from a few weeks back.
How many users clear Battery Stats when installing new roms?
It ran fine for almost 24 hours, then kept hearing the thunder sound. Would come up to the home screen and attempt to load the weather widget. Then bam. The BAMF screen and repeat.
Might wait and attempt if a new one comes out. Good thing I keep plenty of backups at the ready. :)
so is there anything new regarding the mobile hot spot? the fix on page one didnt work. if not i'm gonna go back to my older rom
I do, especially when installing a brand new ROM. Always be sure to have your phone fully charged prior to installing if you do plan on wiping battery stats.
Well, I can safely say that this and shiftsense both have that dreaded VM indicator bug.
Found out I had two unread VM.
Grrrrrrrrrrrrrrrrrrrrrrrrrrrr. :)
What doesn't work, Im using it now as we speak on my laptop?
The question is, why are you not using google voice fro voicemail?
owo Emmanuel
