[GB][2.11.605.0][Sense3.0]BAMF Forever 1.0.7
Re: [GB][2.11.605.0][Sense3.0]BAMF Forever 1.0.5
On a side note, I need testers for my mobile hotspot fix.
Well what is the "fix" might I ask..Since im not subscribed can I still help in any way?
Not if you arent subscribed, no. It fixes the strings.
I am pretty busy today, so I am leaving you guys with a toy.
Browser enhancement patch. It enables debug menu on every boot, as well as Smooth Rotate, and Google zoom (instead of HTC). It has to be reinstalled after every data wipe or if you decide to reset defaults on browser. Resetting defaults on browser and rebooting will disable changes if you don't like them. I thought the smooth rotate was kind of neat and the Google zooming is very smooth.
Thanks this will actually make me use the stock browser, the zoom has never been this smooth and love the screen rotation animation.
I NEED HELP!! Ok so i flashed it to 1.0.4 fine deleted the bamf extras and then installed the 1.0.5 patch. My issue is my phone keeps rebooting over and over again like it's crashing? whats causing this I checked the md5 and they were fine is there any help or should i just try wiping again and flashing it again??
am i subscribed to verizon for the hot spot? no i am not
Delete BAMF_Extra folder before flashing 1.0.4... but it sounds like something did not get loaded correctly... try doing it again... delete the BAMF folder... wipe data, wipe cache, wipe dalvik cache... flash ROM... flash 1.0.5 patch... boot up.
Reactions: surfrj200
lol, you're not going to get the hotspot without subscribing with these newer ROMS. I'm sure you know that older ROMS like BAMF 1.8 have it for free if that's what you're looking for. Wireless Tether works fine for me on these newer builds. I freeze the tetherguard app with Titanium Backup for good measure as well.
ohhh ya thats what i was refering to, i figured since were rooted and all that it would be free like the other roms. so why would we use this rom if its not free? lol. ok thank you.
That happened to me as well.... I just went back to shiftsense until I have time to regroup.
alright did what fatboy 97 told me to do.. I thought i did that before i factory wiped 3 times to make sure lol and did both caches seems like it's working fine not getting my hopes up though because i just did it... i hope i don't run into any problems because i love this rom.. Any recommendations on what radio to use?
alright did what fatboy 97 told me to do.. I thought i did that before i factory wiped 3 times to make sure lol and did both caches seems like it's working fine not getting my hopes up though because i just did it... I hope i don't run into any problems because i love this rom.. Any recommendations on what radio to use?
2.11.605.0 ruu:
CDMA
LTE
U need both radios to work (especially if you're in a 4G area) You're welcome. :)
I would just like to say that this ROM is unbelievable.
SO fast and smooth. I was a huge ASOP fan and advocate, but this ROM took sense to another level.
Thanks Adrynalyne You are the BOMB
What radio do you guys use for the ROM?
Two birds with one stone!!!
Check out the "Latest Radio's" link in my signature below... I'm using 2.11 CDMA radio, and the 2.10 LTE radio just because they did not update the LTE radio in 2.11.... they have been working very well for me.
Can anyone please help me with the mms force close problem? I can't send or receive them. If I get one to send it takes about a day before the other person gets it. I had this problem on uber too.
Also immediately after reboot I get a force close message.
Sent from my ADR6400L using Tapatalk
bummer... it's doing it again.. :(( it was working great for about 5 hours but then last night at 3 in the morning it did it again and woke me up.... all it does is reboot back to the splash screen and goes through the das bamf boot screen then it goes to the lock screen and repeats that cycle over and over again till i pull the battery...:(
can that be a radio issue? because i didn't have the most up to date one.. Im a noob so i just updated the radios to 2.11.605.0 ruu thanks to fatboy 97 and droid_evo_8 thanks both of you for the help!
