[GB][2.11.605.0][Sense3.0]BAMF Forever 1.0.7
Re: [GB][2.11.605.0][Sense3.0]BAMF Forever 1.0.5
the mobile hot spot isnt working. its telling me i have to subscribe to verizon
how do you install that? like a zip file?
Email it to yourself... open the email on your device... click the "Install" button... you will need to have Settings > Applications > "Unknown sources" checked, otherwise it will ask you to do that for you to install this apk file.
Well, I can safely say that this and shiftsense both have that dreaded VM indicator bug.
Found out I had two unread VM.
Grrrrrrrrrrrrrrrrrrrrrrrrrrrr. :)
You mean...the bug that EVERY Sense GB release has had? Don't put that on me.
Still loving the hell out of this rom (well 1.0.2 :P)..My question is, can we install custom lock rings? I had a Sons of Anarchy one made for me over on XDA from redmodian (?), but when I install it thru recovery, nothing changes, even though it worked on Shiftsense. I even tried the Forever Stock zip first, then mine,still no go
Did not mean to toss blame your way. Hence, the shiftsense (and GB leaks) had it as well.
Would you have an idea why after 10 or so hours it would keep rebooting?
Clean wipe of everything and installed 1.0.4, then the 1.0.5 update. No mods or tweeks.
I was really enjoying it.
Not without a logcat. If its still doing it, even after a reinstall...
Might want to check if cwr, reboots. You might have bricked.
Ok, not sure it bricked. Was working great then I would hear thunder and saw the BAMF boot animation. Then would keep doing it. Finally got it to stop and CWR the shiftsense I had prev saved.
Maybe a fresh reinstall later this weekend when I have some time to kill.
im a little lost... to flash 1.0.4 says "Additional notes for 1.0.4
Delete BAMF_Extras from sdcard before flashing
MUST WIPE" i understand i have to wipe the systemnm but where im lost is to delete BAMF_Extras from sdcard before flashing ....should i unzip the 1.0.4- zip folder , delete that extras folder then rezip ?
No..if you have BAMF installed now you have a folder on your sd card called Extras..delete that one..not the one in the zip :)
nevermind this post but thanks!!
On a side note, I need testers for my mobile hotspot fix.
Well what is the "fix" might I ask..Since im not subscribed can I still help in any way?
Thank You, in my post for the fix reported to be for the stock Hotspot to work, it was made to stop the lockup issue that happened when you opened the Hotspot app.
I pay for the feature so I dont go through the process of getting the unpaid versions..
Don't install unapproved mods or mods not meant for BAMF Forever. Fair warning. Hate to see soft bricked devices.
Multiupload.com - upload your files to multiple file hosting sites!
Just notice your version of Hotspot, I'll give it a shot and get back to you on it....
UPDATE: Its good you fixed the notification alert and connects without lockup.. Looks like the widget may need tweaking to toggle Hotspot on,,, Thank You for update..
Reactions: Adrynalyne
All I can Say... THIS IS THE BEST ROM I HAVE EVER USED!!! I cant believe the mods and patches and just the fact that for once, I have no need to flash a different kernel... everything works perfectly... I could keep on rambling on but you get my point... thank you Adrynalyn. you are the man....
I have been through every aspect, nook and cranny of this ROM and have not yet found a bug. the only thing I had to fix was to flash the 2.1 patch for the call answer bug, other than that, this ROM is truly one of a kind.
BAMForever 1.0.5 with alot of mods on it :)
I agree with above, it's a beast of a ROM! To think it's as smooth as it is with stock kernel and not OC'ed, can't wait to see this thing fly running 1.4Ghz or more! Thanks BAMF team!
aimalee
