[GB][2.11.605.0][Sense3.0]BAMF Forever 1.0.7
Anyone know how to change the transparent rosie at the bottom to stock rosie? Love the rom but im ocd about the transparency at the bottom lol.
First, when you say you loaded the ROM... did you wipe data, cache and dalvik cache prior to loading this ROM??? Second, when you say you reloaded data from Titanium... I hope you did not load any system data, and only app data... what did you reload??? Finally, was the weather lock screen the screen you selected, and are all your apps in your applications list.... and did you reboot your device after loading all your apps (shouldn't have to, but it's a good idea if you have issues)???
I believe the problem.was that i restored apps AND system data.. that caused the issue... i re wiped and reflashed and im good to go now... other than getting "no weather forecast available" on the lock screen.. how can i fix that? thanks for your help.
Two things might cause this that I can think of right now... first, under Settings > Accounts & sync > Weather > make sure both Sync weather and Update when opened is checked, and check how often the Update is set to. Second, go back to Settings > Location > make sure Google Location Services is checked... otherwise you have no way for your device to know where you are.
Yess activating google location fixed it.. awesome.. hopefully i get a decent battery life or its going back.. thank you for your help. i really appreciate it.
getting ready flash this. just to be sure bamf sense 3.0 rc4.9 doesn't have the bamf extras folder to delete? i searched for it with root explorer but couldn't find it.
I had to switch back to the original kernel from the 3.8 leankernel.
Battery life was just bad.
I couldn't make it eight hours with my extended battery (usually lasted two days).
Hopefully the kernel IMO had posted as original was truly the original I had so much luck with.
Is really sad to see my Quadrant scores drop from 2300+ back down to sub 1400:'(
Anyone having issues with Visual Voicemail? I press ACCEPT for the EULA, and then it jsut sits there trying to activate it, and it never happens. I've tried in several different areas of coverage, as well as wifi, and nothing..
And no, I don't use Google Voice
It won't work if you restored it from a backup. Uninstall then download straight from the market
When was the last time you've calibrated your battery?
I just installed version 1.0.7 and for some reason I can't connect to the mobile network. In Settings/Wireless & Networks, my "Mobile Network" setting is greyed out, it won't let me connect.
Any idea why this may happen?
Did you upgrade your radio to a Gingerbread Radio???
running the bamf . sense 3.0 .. For some reason the twitter app keeps force closing. I did delete Peep earlier in the day so i thought that may have caused it. I reinstalled from the backup on my titanium. but it still force closes... any ideas on how to get it working again? that was the only one that scrolled on the home page. any help would be appreciated. Thanks..
Upgrade to BAMF Forever.
that is what im running.. sorry if that was not clear..
Sorry, but no it was not... BAMF Sense 3.0 is not BAMF Forever 1.0.7.
Did you reload the data when you reloaded the app from Titanium, or just the app? Maybe there is something corrupt in the data.
Babby bobby billy
