[GB][2.11.605.0][Sense3.0]BAMF Forever 1.0.7
Did you upgrade your radio to a Gingerbread Radio???
At first no, but then I went and installed the gingerbread radio version 2.6.35.10-ge8d3693, but the mobile network option is still greyed out.
It also says my software version is 2.11.605.3
I only flashed the LTE radio, not the CDMA, do I need to do both?
Yes, flash both an LTE and a CDMA radio.
i suppose it is.. but i re installed it and rebooted..the Twitter app keeps force closing... any ideas?
Go into Manage Applications and try clearing data for that app. That has worked for me in the past when I had same problem with another app.
when i find "peep" in my applications, its there but not highlighted like all the others. so i cant clear the data or anything... any ideas?
It would be great if you could come back and post if that is still true in a week or two. I'm also curious....did you ever have data drops on stock rom?
I have a theory (probably simple-minded) that these drops occur when you enter a LTE zone with a signal that is very weak or nonexistant. I find I am most likely to have a data drop requiring a restart right after I leave an area I know has no signal
Perhaps.if I waited 20 or 30 minutes the data would come back. The question is what is going on in the phone during the 10 or 20 minute period when I am back in a good signal zone yet the phone picks up no data?
I would say the problem seems to have pretty much gone away. I havent been on the stock rom for several months. I flashed my first froyo rom in May I believe and didnt have any issues until the last Gingeritis 3d rom that was released. I finally gave that up because of the camera issue. This current 1.0.7 Forever rom has been rock solid since I flashed it over a week ago now. The data drops are probably a big reason Verizon pulled the update until they can sort out the radio to play nicely with their oem rom. Fortunately, I dont have to depend on them to fix that due to the awesome dev community behind this phone.
As far as being on the fringe of an LTE zone, I live smack dab in the middle of DFW. I never saw the 3G icon once until about a month ago when the problems started. Made me wonder if it was more of a network issues rather than my phone.
Been running 1.0.7 since last Friday. Love this ROM. Much thanks to the devs.
There are only a couple of issues I've found. I'm not sure if these are inherent to GB, or not. I've not seen mention of the first two: 1) Settings/Calls/Voicemail Settings. After a reboot, it wipes the phone number info I've stored for this. Didn't have this issue, on Froyo. I like to put my pin there, so I can just tap the notification and it dials VM and enters my pin after a pause. 2) Upon booting to the homescreen, no icons or widgets are drawn. In fact, they will not draw until I actually touch the screen. This could possibly be to a couple of widgets I have running at startup though.
The last issue didn't seem to start until after I tried out Imo's 3.8 kernel. On that kernel, I noticed my battery life nosediving even in standby. Before I flashed that kernel, I was getting pretty nice battery life (wiped battery stats after installing ROM). I flashed back to the stock kernel. The past two days I've monitored it and it's still nosediving even in standby. Example, today in a period of 45min I read 2 and wrote 1 emails. Battery dropped 12% in that period of time. I do not have BT or GPS enabled and I also have all autosyncs turned off (facebook, mail, etc...). I'm going to try wiping battery stats, again. I'm pretty sure that I've got something running that I don't realize yet. I did notice 3 instances of Calender running, under services.
I just wanted to see if anyone has seen the first 2 issues I've listed.
Not receiving texts at all this afternoon. My fiance also has Verizon, she can see mine but im not getting hers.. Any ideas?
Hi
Love this rom but have a few issues.
I have noticed two issues. (I did search for "youtube" in this thread with no results returned)
1.) Youtube - Seems to be flashing green for all video's every few frames.
2.) Car Dock - Along with the stock GB from Verizon, this rom does not initiate the Car Dock.
Does anyone else have these issues?
Thanks
Dave
I am on 1.0.6 right now and battery life has been less than stellar compared to heir RC4.9 I was running previously. Did a battery stats reset and everything. Woke up today had 51%, turned 3G on downloaded 2 apps and played a game for 5 minutes and was down to 32% within a half hour. So any ideas?
Maybe this just doesnt jive with my phone so I will be updating to 1.0.7 today and see if things are different. I will make sure I do the flash with full battery or whatever that is for my phone.
I was wondering if anyone else noticed that the option to disable 4G isn't in this rom or am I overlooking the option?
So after I flashed this from 1.0.6, my gmail doesn't seem to be syncing correctly. The image attached, shows 1 new, but above it shows 7 new. It worked correctly on 1.0.6, anyone else having this problem?
Sent from my Bamf'd HTC Thunderbolt using Tapatalk
I am having the same problem in stock for whatever that's worth.
Can anyone verify if touchdown works in this rom?
How about VZW VVM?
Click to view quoted image
Totally irrelevant, but how do you get that kick ass font?
How about VZW VVM?
I don't use VZW Vvm, I'm cheap and use Youmail instead lol
trimiqukbuy
