Can I run Stupidfast with the stock rom and which rooting method would allow me to do so? Thanks and awesome write-up!
Thanks for the reply. If rooted, what would I have to do to be able to move my apps to my sd card instead of having them take up space on my memory card or is there even a way? And does one click root give me the privilege of loading superfast to my phone, and if so, what would be the procedure? Thanks again for all your wonderful help.
Thanks again. I wasn't sure if the new leaked 2.2 Froyo ROM was able to. I knew it was a 2.2 thing. Just didn't know if developers were able to incorporate that into the new ROM's somehow. Thanks again for the help. So what's the difference in procedures to load a kernel versus loading a rom? Do you use something like ROM manager for kernels or what? Thanks again.
That's why I was asking about stupid fast with the stock rom. If it'd be a good match? How would I find out what makes a good pair like you're talking about? Thanks again. I'm feeling so close to starting. So what's the advantage of using cwm recovery + root over using the one click root and rom manager if they both can accomplish the same thing? Once again... Thank you for all your help. One more thing... Backing everything up... I've heard about titanium and nandroid. Which is best and which is easier? both performed prior to loading something new on the phone?
Thanks for the great writeup. Have been thinking about loading different rom/kernal but seemed like there was not a clear easy guide. Have done lots of reading but would find conflicting info. Yours seems to be the clearest and most easy to follow I have seen.
Sheepdog - is DL30 the leaked 2.2 update? I see you're running it. How's it been so far. I asked it before, and I think you answered it, but just because it's a quote 2.2 rom, doesn't mean it's true (and we still can't move apps to our sd cards), right? Thanks for the help again.
What is the best and easiest root for the fascinate. I only wanna root it for the wireless tether option and that is it. What would you recommend
