How can I fix a GPS Problem?
  • Start date Start date
A
AC Question
GPS Problem
Hello guys,
I have a Lenovo A-5500 Tab and I've been encountering some gps issues regarding my location, it's worthwhile mentioning that I test GPS indoors
The blue dot gets my location but it doesn't move with me, it drifts away and bounces as far as 1 mile or more from where I am. I tried most of GPS tools, reinstalled my A-GPS data and cleared it with toolboxes, still the problem presists, I've even tried it outdoors but for a short period of time (to see if the blue dot will move along with me) and it didn't work properly.. any suggestions?
Re: GPS Problem
Maybe try GPS Fix from the play store. It should tell you how many satellites that is pinging your location, if it is a low number, than that could be your issue.
Marioprattes
