How do you remove Picasa albums from phone
Yesterday I went to the actual Picasa website.from my computer . It auto logged me on since I was logged into gmail. Then one by one I erased my albums. Double check my settings. Then went to my phone double checked my settings for Google +. Wiped cache for the app. Rebooted. Problem solved. Picasa gone.
Okay, so I was going crazy trying to figure out how to delete photos from Picasa in my Samsung Galaxy S3. I couldn't delete them from my phone and then I would log onto Picasa on my laptop and the pictures weren't even showing! Finally, I found a free app that I downloaded and I was able to go into it and delete my photos from Picasa. The app is called Picazza. Once you download it, open it and you'll see all of your Picasa albums. Click on an album and hold it until a menu pops up and one of the selections will be "Delete Album". I also went into my phone settings - application manager - and swiped over to view all applications running. Then, I went down to Picasa and disabled the application. I suggest doing this too! I hope this helps someone because I know that it was driving me crazy!
Go onto your gallery, press the file button, click 'settings' and click on your gmail account then untick all the boxes apart from "google photos" then click "remove account" which is at the bottom right hand corner. This deletes the Picasa photos from your gallery. Hope this helps :)
Tried that it didn't work. When I clicked on Google the next screen only had Google + and some other options and at the bottom an item to click on that said "sync all" when I did click on it got the message sync cancelled but it didn't do it.
Thx for the tips. However before I click "clear data"
I would like to know if it wipes out all other pics
from other non-picasa albums in my phone too?
Guys try this... it ll work.
1 Open Settings, scroll down and tap Application Manager
2 Tap All
3 Select Google+
4 Tap Uninstall Updates
5 Return to home screen by pressing middle button
6 Find Google+ in apps menu and open it
7 Follow setup steps, when prompted about Auto Uploads choose to turn them off
8 Close Google+
9 Open Settings, scroll down and tap Accounts and Sync
10 Select your Google account (long press)
11 Untick these options if available: Sync Google+, Sync Google Photos, Sync Picasa Web Albums
12 Tap Sync now at the bottom
13 Tap Back arrow twice to return to main settings screen
14 Open Application Manager
15 Tap All
16 Scroll down and tap Gallery
17 Tap Clear Data
18 Return to home screen by pressing middle button
19 Open Gallery app, you should now find that the Picasa albums are gone!
I don't have "Unsync Picasa web albums" on my phone. I do have "Sync Google Photos", is that the same as Picasa?
websitedesig101
