How to change boot animations and mp3 in new froyo leak
speaking of boot animations...i noticed during the new froyo animation, when it briefly flashes all the features of the phone, it shows 'google android 2.1'...oops
Any advice on removing the new boot audio when I get the 2.2 update?
Im fine with the animation, I just dont want my Incredible going 'Droooiiid' every time it turns on when I may not be in an environment where I want it to make noise.
Im kind of a noob with all of the techincal android stuff, but Ive managed to change the animation a couple times before with 2.1 and that seemed relatively easy when I got everything set up correctly.
Any help is appreciated.
Does anyone know if ROM Manager will handle this issue with 2.2?? I've changed boot animations with it in 2.1 with no issues, but have not tried it yet with 2.2
2.2 is a bit different in that I think you need root access to accomplish it. You have to get write (mount) access to the system folder:
/system/customize/resource
In clockwork mod recovery, you mount /system, plug in the phone, then from adb, you can move the sound file:
adb shell
mv /system/customize/resource/VZW_Droid.mp3 /system/customize/resource/VZW_Droid.bak
That will move the file to a backup, and prevent the sound from playing.
grr. this is frustrating. all I get after I try and push the animation is " /sbin/sh: adb: not found"
It looks like you're running adb shell before running adb push. When you run adb shell, that takes you into the phones OS. So if you try to run a command, it runs it on the phone (hence, the system saying adb is not found...because it's on your PC, and not the phone). Try typing: exit, then adb push your file.
2.2 froyo PC-style boot animation
Oh, and if anyone's interested, I changed that PC BIOS boot animation to have 2.2 version numbers (see screenshot). We have 2.2 now, I figured the boot animation should reflect that.
Tested on my phone and working.
I'm back on SR3 since gmail kept FCing with virtouos 2.3. If I try and go back I'll try your suggestion. Thanks for the help.
I'm pullin my hair out here... Astro allows me to see the VZW_bootanimation.zip file in /system/customize/resource/ but not delete it. ADB Shell reports "file does not exist" on a rm command. I can ADB push the new animation, but then always receive black screen.
What am I doing wrong?!!
What font are you using? I want to make a few changes to have it match my config
I am in the same boat but have not rooted. I am a tech n00b and I know just about enough to screw up my DInc so I am hesitant to root.
I have searched for a non-root way to remove the audio, but have come up empty. Anyone had luck on this?
They only way to get rid of the boot audio is to be rooted. You need to be able to mount the system partition as read/write. In froyo, they're kept in /system/customize/resource/ as VZW_bootanimation.zip and .mp3. Change the mp3 to .bak and it'll stop.
I have a custom ROM with the boot audio removed by default. I want to put it back to see what it's like. Anyone know where I can get the stock Incredible audio file?
If you can get your phone into recovery mode you can remove it without being rooted. But it's going to be aggravating, and by the time you get that you might as well root....so just root it and be happy, you can always unroot it after getting the sound gone.
Stock VZW file sure: VZW Bootanimation Sound
Just curious, what exactly are you guys seeing that is showing you that your 3G broke after applying boot animation?
how do you put the audio back in? can it be easily done with root explorer, or do i have to use adb?
Obviously you must be rooted. But with root explorer just mount the directory R/W and copy it back in there. Reboot the phone.
LordDAXVader
