[HOW-TO] Download/Install Honeycomb to Nook Color (SD card)
I wrote the .img to the SD card, NC booted to Android screen, but now is asking for "passwor to decrypt storage"? Help!
Hey, my daughter is in China, and before I left I did built a microSD card for her using CM7.
Her problem is her quick launch bar lost its App Launcher icon. She only gets a second star instead of Launcher / Star / Globe.
She now has no way to access her programs except via search.
Can she fix this easily or do we need to recover somehow?
Thanks
I did this and now my SD card is only 113 Meg where it used to be 4 gig. What the hell happened?
You need to mount the SD card on a Linux box and run "parted" to resize the /sdcard partition. If you're not familiar with Linux, download a partition manager for Windows and resize it. It's a FAT32 partition so Windows should be able to deal with this. The reason you're seeing this because the original Honeycomb image was pulled off of a 4G SD card and the partition are organized such that /sdcard is only 1.5G.
I think this was asked but I cannot find entry, did this process and first Will Shanklin thank you so much for the write up, it went pretty smoothly and your process was easy to understand, this will be a noob questions but I did this on a 16gb sd card when I wrote the image to the SD it made 4 partitions, 1 at 118mb,1 at about 4gb, 1 at x mb (sorry can remember the space) and then the last was left a un-partitions space at about 11gb and change, how do it get the 11 gb to a usable state and if I need to increase a partitions ( which I thought you could not do) which one do I increase, sorry for the long explanation and for the 2 part questions, once again thanks to Will Shanklin and everyone who contributed great job on this
Just a question,
I have put the software on a micro SD card and booted up the nook with it. It sort of worked, I get a screen with the time and date, but that's it. I have the open padlock, which when you press it you get the rings, but nothing is happening.
What do I have to expect or do????
HELP Please,
I got the market installed, can use wifi to browse the web, but when I try to authenticate my market or gmail account it wants to use a data plan, it will not go through WIFI, therefore it fails every time, has anyone else experienced this?
Any ideas will be helpful!
Thanks:confused:
Thanks
On a open portion of the nook screen touch it till it displays the Add To Home Screen options box and select Launcher Options, Move to Desktop and then touch and drag the launcher icon onto the star to replace the missing launcher. I don't know what causes the launcher to disappear but this will restore it.
You can do this on windows by running the MiniTool Partition Wizard Free Partition Magic alternative. Free Partition Manager Software for Windows 7/VISTA/XP/2000 and Windows Server 2003/2008/2000.
Hello finally gave up and decided to ask for help. My OS is Windows x64. I have HC installed on 8gb miniSD card.
I installed the android sdk and NC USB drivers.
Device Manager shows
Android Phone
Android Composite ADB Device
Disk Drives
B&N Ebook Disk USB Device
Universal Serial Bus Controllers
USB Composite Device
USB Mass Storage Device
adb devices yield -> 11223344556677 device offline and i can not access the sd card from my PC.
What I've tried:
Toggling USB Debuggin on/off
Unplugging/plugging NC
Rebooting NC
Restarting PC
Nothing worked.
I'm having problems getting WINIMAGE to copy the Nook Honeycomb image to the SD card. Everytime I try doing it, it errors out with a blank error pop-up. I've used the EAUS utility to reallocate the SD card to full size, but can't seem to get the WINIMAGE write to work.
theblairs. Try WinRAR to copy the Nook Honeycomb image to the micro SD. Here's the link: WinRAR download and support: Download now.
First quick apology, this is my first comment/question on this website and I am new to Android....
1) So is the method on the first page of this thread still the best way to get honeycomb on my nook, this is my first time rooting it....I realized that a bit of time has passed since this thread was first posted...
2) Anybody know any good books or material to use to learn all about Android??
Thanks a lot!!
so i'm using my macbook pro to download the nook honey to my microSD with a dynex writer. when i go to find file, this come us (no such file or directory) I was able to unmount the SD, so i have been trying to down load and unzip the file like 5 time. I also downloaded Stuffit expander to help unzip file.
No luck file still can't be found.
Please help a newbie.
thanks
chuck
I just installed everything (honeycomb, google apps etc...) and when Itry downloading from the marketplace I get the little box that says your file will download but then it dosent download, tried rebooting with no luck, any suggestions?
When I type this command line in mac dd if=nookhoney04.img of=/dev/rdisk# bs=1m all I get is a message that no such file or directory? What am I doing wrong.
dumpsterrentals89
