[HOW-TO] Flashable Zip: Install Honeycomb to Internal Memory (eMMC) of Nook Color
Did the flashable zip last night with out much issue.
Nook frooze up after the 3 formats which freaked me out a bit. Got it to reboot and ran the install and had Honeycomb installed and running after reboot.
I did have a market issue where it wouldn't download anything. I followed the instructions in the initial post about force stop and data wipe and it fixed it.
So far so good! Can't wait for an official release of Honeycomb to be ported over :)
skapp02: My market won't download anything either... what specifically did you wipe? I tried clearing the market cache under 'manage apps' and force stopping it, but neither helped.
Thanks,
- Phil
So I found a site that said clear the data from the Google Services Framework app, which I did, and then apps would download again... but only 2 then it stopped.
When I once again cleared the GSF data, the market stopped being able to launch altogether. It says "An error has occurred. Please try again later" every time I launch it, and then closes.
I've tried rebooting to no affect... anyone know how I can unbreak it?
You do realize this ZIP is outdated. There is a 2nd edition which fixes most of the bugs mentioned above.
See XDA original thread..
The OP should check for updates..
Need a little help. Honeycomb working well. Just one issue. When I go online to yahoo and try to sign in to one of my yahoo emails the screen flashes back to my home screen. What happened??
I followed the steps below from the original post on how to install to eMMC
* If you have problems downloading from the Market, under Settings, go to Applications>Manage Applications>Google Services Framework - and choose wipe data and force stop. Still under Manage Applications, choose Market, and force stop. Then reboot and see if it works.
Just installed and stuff seems to be working well.
One question: under Settings->Storage->Internal Storage only 0.92GB shows for total space. Shouldn't the NC have a lot more than that?
Thanks for all the awesome work!
Just a little heads up, but a flashlight app caused a complete crash and I had to do a fresh reformat. Just make sure to avoid certain apps.
Anyone else having problems with market in this build? it won't display the home screen, but i can search to my heart's desire
Ya. I'm having problems with market, it looks like it's working but only actually installs a few apps. I was only able to install angry birds. Other apps like Quadrant Standard and almost all other apps don't download and install. :'(
Does this edition require a complete wipe? I just got the old version configured like i want it.
Yes it does. Remember, this is still a beta-level hack of HC onto the nook. I expect updates will require a wipe for a quite a while more.
- Phil
- Phil
Thanks Phil, I'll give it some more updates then before I do an update then.
Fixed it with tricks on 1st page of this forum and by unmounting and remounting SD card when getting error 18
Same here. Unmounting SD, downloading apk and installing, then re-mounting , was the only way I was able to install several apps.
Yeah - market is "wonky"
It installs apps but does not show them in the list for "my apps"
Overall this is very close ... though I feel like HC from SD card has less issue (but is obviously really slow in comparison)
This build seems to be more unstable than the previous one. I have everything working just right on the first build, there is no way I am flashing this one.
can some one give me a link for the clockwork mod recovery image download. When I click on it, it tells me theres a newer version?
LiveBarney
