[HOW-TO] Flashable Zip: Install Honeycomb to Internal Memory (eMMC) of Nook Color
Follow the OP directions, but only "dd" over the hc4bootOC.img file and reboot. SetCPU is in readonly mode for me (due to my messing with su versions), but it does show 1100 as you play with Nook.
Reactions: jordan8201
Just loaded the OC boot image only and I'm still running. SetCPU can't get su permission due to my previous overwrite of su.
To get root access back, just follow the directions in the root Honeycomb thread, replacing mmcblk1p2 with mmcblk0p5.
Followed your directions and got su back. SetCPU and Titanium Backup now work. RootExplorer doesn't. Oh, well. Still OCing just fine. Thanks again.
I followed the directions and when I unmounted and removed the SD card and rebooted from Clockwork, it gets stuck at a screen that says "ANDROID" with a blinking cursor. Any thoughts?
Anyone else having problems with market in this build? it won't display the home screen, but i can search to my heart's desire
OP updated - it looks like the flashable zip is probably in good shape, so I included in instructions!
Hats off to those working on this, wish I was smart enough. Wonder if a boot selector between Honeycomb and Froyo for your Nook would be possible.
I see the flashable zip is out, much thanks :), is it using the standard 800mhz kernel or the 1.1ghz ?
This is awesome.
Anyone else having issues with the Market? It seems to be fine to list apps and maybe download them but not install them? I'll see the "your item will be downloaded" screen and then it quickly just goes back to listing all the apps I have purchased. It installed just one -- angry birds -- the rest are just sitting there undownloaded/not installed.
Am I missing a simple step?
Using the flashable zip btw. Anyone else seeing this issue?
This is awesome.
Have you tried these steps
* If you have problems downloading from the Market, under Settings, go to Applications>Manage Applications>Google Services Framework - and choose wipe data and force stop. Still under Manage Applications, choose Market, and force stop. Then reboot and see if it works.
* If it isn't reading your SD card, power down, insert your SD before powering on, then boot up.
Reactions: will02128
After installing the zip, I get stuck on the "ANDROID _" flashing cursor. Any recommendations?
Owolabiempire
