[How-to] Guide to Rooting with software version LS670ZVC
Status
Not open for further replies.
Hey All,
Thanks for responding. I'll stop banging my head against the wall and phone against my head.
Currently, i do not have access to a windows machine or a windows license (at work or at home). Perhaps i'll try to mooch of a friend in the future, for the moment i'll just use the stock phone.
i'll keep my fingers crossed for an alternative method for rooting. Has anyone figured out the difference from OTA update v. LGMobile update program?
in the mean time, i'll take some aspin. Cheers and thanks!
- bkn
At the moment, there isn't really an alternative method.
The difference between OTA and LGMobile is that the OTA update also updates the recovery kernel. The LG update does not.
Would itbe possible to install a root kit while in v9 (with root) then upgrade to VC and execute the root kit? Sorry if this has been suggested before but scanning through 50+ pages of posts is a though way to find info.
You don't need to scan, it's called "search" for a reason :p
If you mean running RageAgainstTheCage on OTA VC don't even try. It simply will not work. You need to be updated to VC using the LGMobile update tool and you need to follow the instructions carefully in the LS670ZVC rooting guide.
You can also use the LG Optimus S Control Center. Note that some users have been reporting issues, but I have a hunch those issues are coming from user error.
Well played! Good point.
No I was thinking that if one has root on V9 then prior to the upgrade one installs a piece of sofware not affected by the update but still can execute after the upgrade to.get a root shell. Oh how I miss the thunderom!
Thanks again for the info it helps me better understand how things work. Cheers.
The point of VC is it patches known root exploits (rage is the one that has worked prior to VC).
So yes, you could do what you suggest. You would just need to figure out a new exploit which hasn't been patched yet.
Hello can someone give me some information on what im suppose to do. My issue is i tried to use the lg optimus control center method but i would get to the step were the phone would disconnect once and thats it. I tried the method several times iw ould just follow through with steps but i never got superuser on phone. I next decided to try and revert back to v9 to then try and use z4root but i got to step Q everything was completed and now my phone reboots with lg screen but after that i cant see anything else!! Is my phone bricked? Do i need to do a unbrick method? Any help will be appreciated thank you!
At step (q) it is flashing the phone and not complete yet. What caused you to stop at that step? Was there an error? Could you post the error?
You can try this method:
http://forum.androidcentral.com/lg-...icularly-after-vc-update-possible-fix-es.html
If that doesn't work you can try alternating:
Pull battery
Insert battery
Press and Hold 3 seconds - Power + Vol- + Home
Pull battery
Insert battery
Press and Hold 3 seconds - Power + Vol+ + Home
You might need to do this many times.
I haven't tested this, but running the LG tool MIGHT work in Linux using the latest version of Wine.
Note to anyone else, i did try wine on OS X, however wine doesn't have much/any support for usb devices and drivers; that support should be in the next release, wine-1.4, but that's not available at the moment.
thanks for the suggesting though, the software runs great in wine until it needs to access the usb devices.
/sdcard#/system/bin/chmod 777 /sdcard/rageagainstthecage
/dbin/dh:/system/bin/chmod: not found
wtf... place tell where you place the files i got them all in platform-tools in my tools folder
Thanx for the reply sfhub. Im sorry i didn't actually stop at step (q) i finished the completion as was mentioned on step S. When it reboots i see the lg screen and after that i hear the sprint logo screen that comes up after that but i cant see anything. Im going to try and start the process over again and post the log!
Pull battery
Insert battery
Pull battery
Insert battery
ok well it seems when i did that power vol home a couple times then it seems i can get into the recovery mode area where its saying its trying to find update package..
E: cant find commad file cache: recovery/command
installation aborted no valid image cache.
this might be a dumb question but in the reverting to v9 process was i suppose to be the recovery mode area n the phone before the LG Software Updater Tool started?
Here is the log sfhub thanx for taking a look at it. Do you see any abnomalities?
21:08:48 : [C:\LGMobileUpgrade] ???丮 ???? ?õ?
21:08:48 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
21:08:48 : Start Date : 2011-02-27 21:08:48
21:08:48 : -------- Buyer Test mode ---------
21:08:48 : [C:\ProgramData\LGMOBILEAX\Phone\BIN] ???丮 ???? ?õ?
21:08:48 : [C:\ProgramData\LGMOBILEAX\Phone] ???丮 ???? ?õ?
21:08:48 : *****CheckOS Start********
21:08:48 : Microsoft_Windows_Vista Home Edition_
21:08:48 : *****CheckPCSyncPrograms Start*****
21:08:48 : PCSyncPrograms Not Found
21:08:48 : SetEmerModeAT()
21:08:48 : _IsConnectedPhone Call
21:08:54 : _IsConnectedPhone(1)
21:08:54 : 0 - NotConnected.
21:08:54 : 1 - Normal connect success
21:08:54 : 2 - Emergency connect success
21:09:49 : Checking the connection with the cell phone...
21:09:49 : dwWaitResetTime(40000 ms)
21:09:50 : Phone Mode(1)
21:09:50 : *****GetPhoneType Start*****
21:09:52 : Phone Type : CDMA
21:09:52 : *****Start GetPreviousStep*****
21:09:52 : _GetPreviousStep(dwStep:0xffff)
21:09:52 : _SetPhoneNumber retval=1
21:09:52 : *****GetPhoneModel Start*****
21:09:54 : *****GetPhoneBinaryVersion Start*****
21:09:54 : Phone Bin Version : LS670ZV9_20
21:09:54 : *****Get ESN / IMEI / MEID Start*****
21:09:57 : ESN/IMEI/MEID : A0000028B9AD74
21:09:57 : *****GetPhoneNumber Start*****
21:09:59 : Phone Number : A0000028B9AD74
21:10:00 : ???? ?˻? ?Ķ??Ÿ - ESN_IMEI : A0000028B9AD74, Model :
21:10:00 : *******CheckBinVersion***************
21:10:00 : New Bin Version(ls670v9_20), Current Ver(LS670ZV9_20)
21:10:00 : ?ֽ? ?????̹Ƿ? ???׷??̵带 ?? ?ʿ䰡 ????.
21:10:02 : _GetAuthMark : wAuthMark(4099)
21:10:02 : Wait 3Sec
21:10:08 : _SetAuthMark Ok : wAuthMark(4099), PhoneMode(1)
21:10:08 : *****Start _GetBatteryLevel*****
21:10:10 : Battery(5)
21:10:12 : ResetPhone...
21:10:12 : Checking the connection with the cell phone...
21:10:12 : dwWaitResetTime(40000 ms)
21:10:42 : _IsConnectedPhone Call
21:10:47 : _IsConnectedPhone(1)
21:10:47 : 0 - NotConnected.
21:10:47 : 1 - Normal connect success
21:10:48 : 2 - Emergency connect success
21:10:48 : Phone Mode(1)
21:10:48 : m_dwBootWaitTime(35586)
21:10:48 : Checking the connection with the cell phone...
21:10:48 : dwWaitResetTime(30000 ms)
21:11:18 : _IsConnectedPhone Call
21:11:23 : _IsConnectedPhone(1)
21:11:23 : 0 - NotConnected.
21:11:23 : 1 - Normal connect success
21:11:23 : 2 - Emergency connect success
21:11:23 : Phone Mode(1)
21:11:23 : Call _ModeOffline()
21:11:24 : *****CheckPCSyncPrograms Start*****
21:11:25 : PCSyncPrograms Not Found
21:11:26 : CLGMobileHttp Class ?Ҹ????.
21:11:26 : CLGMobileHttp Class ?Ҹ?...
21:11:26 : ****************CheckAndDownload********************
21:11:26 : ******Extract Start ls670zv9.cab*****
21:11:26 : Model Dll Dir(C:\ProgramData\LGMOBILEAX\Phone\)
21:11:27 : Extracted C:\ProgramData\LGMOBILEAX\Phone\\LS670ZV9_20.S9_20.P60671.wdb\n
21:11:27 : WDB(or DZ) FullPath(C:\ProgramData\LGMOBILEAX\Phone\\LS670ZV9_20.S9_20.P60671.wdb)
21:11:27 : Extracted C:\ProgramData\LGMOBILEAX\Phone\\LS670_W_0_0_2_0.dll\n
21:11:27 : Model dll FullPath(C:\ProgramData\LGMOBILEAX\Phone\\LS670_W_0_0_2_0.dll)
21:11:27 : Extracted C:\ProgramData\LGMOBILEAX\Phone\\LS670ZV9_20.S9_20.P60671.wdh\n
21:11:27 : NNNNN WDB FullPath(C:\ProgramData\LGMOBILEAX\Phone\LS670ZV9_20.S9_20.P60671.wdb)
21:11:27 : NNNNN Model dll FullPath(C:\ProgramData\LGMOBILEAX\Phone\LS670_W_0_0_2_0.dll)
21:11:27 : Extract End ls670zv9.cab
21:11:28 : *****WorkModelDLL Start*****
21:11:29 : strPhoneBinaryPath(C:\ProgramData\LGMOBILEAX\Phone\LS670ZV9_20.S9_20.P60671.wdb)
21:11:29 : strModuleDir(C:\ProgramData\LGMOBILEAX\Phone\)
21:11:29 : strModelDLLPath(C:\ProgramData\LGMOBILEAX\Phone\LS670_W_0_0_2_0.dll)
21:11:29 : m_nPhoneMode(1)
21:11:29 : Phone mode 1 = Normal
21:11:29 : Phone mode 2 = Emergency
21:11:29 : Phone mode 4 = CSE
21:11:29 : _DetachDLL Call
21:11:29 : _DetachDLL Call End
21:11:29 : Call fn_StartUpgrade
21:11:29 : ### Start Upgrade - CDMA ###
21:11:29 : ********* CDMA Model.dll input Parameter *************
21:11:29 : MODEL_EVENT : 32769
21:11:29 : PhoneBinaryPath : C:\ProgramData\LGMOBILEAX\Phone\LS670ZV9_20.S9_20.P60671.wdb
21:11:29 : ModuleDir : C:\ProgramData\LGMOBILEAX\Phone\
21:11:29 : BootWaitTime : 53379
21:11:29 : UsbHighSpeed : FALSE
21:11:29 : PhoneMode : 1
21:11:29 : NewPhoneBinVersion : ls670v9_20
21:11:29 : ClearSI : FALSE
21:11:29 : AuthMark : 4099
21:11:29 : ********* CDMA Model.dll input Parameter End*************
21:11:30 : wParam : 20, lParam = 570
21:11:30 : MODEL DLL Event : (20, 570)
21:11:31 : Model Dll Msg Not Found(20, 570)
21:11:37 : wParam : 4, lParam = 0
21:11:37 : MODEL DLL Event : (4, 0)
21:11:49 : wParam : 5, lParam = 1
21:11:49 : MODEL DLL Event : (5, 1)
21:11:50 : wParam : 5, lParam = 0
21:11:55 : wParam : 5, lParam = 1
21:12:00 : wParam : 5, lParam = 2
21:12:05 : wParam : 5, lParam = 3
21:12:09 : wParam : 5, lParam = 4
21:12:13 : wParam : 5, lParam = 5
21:12:17 : wParam : 5, lParam = 6
21:12:22 : wParam : 5, lParam = 7
21:12:27 : wParam : 5, lParam = 8
21:12:32 : wParam : 5, lParam = 9
21:12:37 : wParam : 20, lParam = 588
21:12:37 : MODEL DLL Event : (20, 588)
21:12:38 : Model Dll Msg Not Found(20, 588)
21:12:38 : wParam : 5, lParam = 10
21:12:43 : wParam : 5, lParam = 11
21:12:48 : wParam : 5, lParam = 12
21:12:53 : wParam : 5, lParam = 13
21:12:58 : wParam : 5, lParam = 14
21:13:03 : wParam : 5, lParam = 15
21:13:08 : wParam : 5, lParam = 16
21:13:13 : wParam : 5, lParam = 17
21:13:18 : wParam : 5, lParam = 18
21:13:22 : wParam : 5, lParam = 19
21:13:27 : wParam : 5, lParam = 20
21:13:32 : wParam : 5, lParam = 21
21:13:37 : wParam : 5, lParam = 22
21:13:42 : wParam : 5, lParam = 23
21:13:47 : wParam : 5, lParam = 24
21:13:52 : wParam : 5, lParam = 25
21:13:58 : wParam : 5, lParam = 26
21:14:03 : wParam : 5, lParam = 27
21:14:08 : wParam : 5, lParam = 28
21:14:13 : wParam : 5, lParam = 29
21:14:18 : wParam : 20, lParam = 510
21:14:18 : MODEL DLL Event : (20, 510)
21:14:18 : Model Dll Msg Not Found(20, 510)
21:14:18 : wParam : 5, lParam = 30
21:14:23 : wParam : 5, lParam = 31
21:14:28 : wParam : 5, lParam = 32
21:14:33 : wParam : 5, lParam = 33
21:14:38 : wParam : 5, lParam = 34
21:14:43 : wParam : 5, lParam = 35
21:14:48 : wParam : 5, lParam = 36
21:14:53 : wParam : 5, lParam = 37
21:14:58 : wParam : 5, lParam = 38
21:15:03 : wParam : 5, lParam = 39
21:15:08 : wParam : 5, lParam = 40
21:15:13 : wParam : 5, lParam = 41
21:15:18 : wParam : 5, lParam = 42
21:15:23 : wParam : 5, lParam = 43
21:15:28 : wParam : 5, lParam = 44
21:15:32 : wParam : 5, lParam = 45
21:15:35 : wParam : 5, lParam = 46
21:15:39 : wParam : 5, lParam = 47
21:15:43 : wParam : 5, lParam = 48
21:15:47 : wParam : 5, lParam = 49
21:15:52 : wParam : 5, lParam = 50
21:15:52 : wParam : 20, lParam = 407
21:15:52 : MODEL DLL Event : (20, 407)
21:15:53 : Model Dll Msg Not Found(20, 407)
21:15:53 : wParam : 5, lParam = 50
21:15:58 : wParam : 5, lParam = 51
21:16:02 : wParam : 5, lParam = 52
21:16:07 : wParam : 5, lParam = 53
21:16:12 : wParam : 5, lParam = 54
21:16:17 : wParam : 5, lParam = 55
21:16:22 : wParam : 5, lParam = 56
21:16:27 : wParam : 5, lParam = 57
21:16:32 : wParam : 5, lParam = 58
21:16:37 : wParam : 5, lParam = 59
21:16:42 : wParam : 5, lParam = 60
21:16:47 : wParam : 5, lParam = 61
21:16:52 : wParam : 5, lParam = 62
21:16:57 : wParam : 5, lParam = 63
21:17:02 : wParam : 5, lParam = 64
21:17:07 : wParam : 5, lParam = 65
21:17:11 : wParam : 5, lParam = 66
21:17:15 : wParam : 5, lParam = 67
21:17:20 : wParam : 5, lParam = 68
21:17:24 : wParam : 5, lParam = 69
21:17:27 : wParam : 20, lParam = 309
21:17:27 : MODEL DLL Event : (20, 309)
21:17:28 : Model Dll Msg Not Found(20, 309)
21:17:28 : wParam : 5, lParam = 70
21:17:32 : wParam : 5, lParam = 71
21:17:36 : wParam : 5, lParam = 72
21:17:40 : wParam : 5, lParam = 73
21:17:45 : wParam : 5, lParam = 74
21:17:50 : wParam : 5, lParam = 75
21:17:55 : wParam : 5, lParam = 76
21:18:00 : wParam : 5, lParam = 77
21:18:05 : wParam : 5, lParam = 78
21:18:10 : wParam : 5, lParam = 79
21:18:15 : wParam : 5, lParam = 80
21:18:20 : wParam : 5, lParam = 81
21:18:25 : wParam : 5, lParam = 82
21:18:30 : wParam : 5, lParam = 83
21:18:35 : wParam : 5, lParam = 84
21:18:40 : wParam : 5, lParam = 85
21:18:45 : wParam : 5, lParam = 86
21:18:50 : wParam : 5, lParam = 87
21:18:55 : wParam : 5, lParam = 88
21:19:00 : wParam : 5, lParam = 89
21:19:05 : wParam : 5, lParam = 90
21:19:10 : wParam : 5, lParam = 91
21:19:15 : wParam : 5, lParam = 92
21:19:20 : wParam : 5, lParam = 93
21:19:25 : wParam : 5, lParam = 94
21:19:30 : wParam : 5, lParam = 95
21:19:35 : wParam : 5, lParam = 96
21:19:40 : wParam : 5, lParam = 97
21:19:45 : wParam : 5, lParam = 98
21:19:50 : wParam : 5, lParam = 99
21:19:55 : wParam : 5, lParam = 100
21:19:55 : wParam : 6, lParam = 0
21:19:55 : MODEL DLL Event : (6, 0)
21:20:23 : wParam : 20, lParam = 110
21:20:23 : MODEL DLL Event : (20, 110)
21:20:23 : Model Dll Msg Not Found(20, 110)
21:20:23 : wParam : 8, lParam = 0
21:20:23 : MODEL DLL Event : (8, 0)
21:21:20 : wParam : 10, lParam = 1
21:21:20 : MODEL DLL Event : (10, 1)
21:21:21 : wParam : 10, lParam = 2
21:21:21 : wParam : 10, lParam = 4
21:21:21 : wParam : 10, lParam = 6
21:21:21 : wParam : 10, lParam = 8
21:21:21 : wParam : 10, lParam = 10
21:21:21 : wParam : 10, lParam = 12
21:21:21 : wParam : 10, lParam = 14
21:21:21 : wParam : 10, lParam = 16
21:21:21 : wParam : 10, lParam = 18
21:21:21 : wParam : 10, lParam = 20
21:21:21 : wParam : 10, lParam = 22
21:21:22 : wParam : 10, lParam = 24
21:21:22 : wParam : 10, lParam = 26
21:21:22 : wParam : 10, lParam = 28
21:21:22 : wParam : 10, lParam = 30
21:21:22 : wParam : 10, lParam = 32
21:21:22 : wParam : 10, lParam = 34
21:21:22 : wParam : 10, lParam = 36
21:21:22 : wParam : 10, lParam = 38
21:21:22 : wParam : 10, lParam = 40
21:21:22 : wParam : 10, lParam = 42
21:21:23 : wParam : 10, lParam = 44
21:21:23 : wParam : 10, lParam = 46
21:21:23 : wParam : 10, lParam = 48
21:21:23 : wParam : 10, lParam = 50
21:21:23 : wParam : 10, lParam = 52
21:21:23 : wParam : 10, lParam = 54
21:21:23 : wParam : 10, lParam = 56
21:21:23 : wParam : 10, lParam = 58
21:21:23 : wParam : 10, lParam = 60
21:21:23 : wParam : 10, lParam = 62
21:21:24 : wParam : 10, lParam = 64
21:21:24 : wParam : 10, lParam = 66
21:21:24 : wParam : 10, lParam = 68
21:21:24 : wParam : 10, lParam = 70
21:21:24 : wParam : 10, lParam = 72
21:21:24 : wParam : 10, lParam = 74
21:21:24 : wParam : 10, lParam = 76
21:21:24 : wParam : 10, lParam = 78
21:21:24 : wParam : 10, lParam = 80
21:21:24 : wParam : 10, lParam = 82
21:21:25 : wParam : 10, lParam = 84
21:21:25 : wParam : 10, lParam = 86
21:21:25 : wParam : 10, lParam = 88
21:21:25 : wParam : 10, lParam = 90
21:21:25 : wParam : 10, lParam = 92
21:21:25 : wParam : 10, lParam = 94
21:21:25 : wParam : 10, lParam = 96
21:21:25 : wParam : 10, lParam = 98
21:21:25 : wParam : 10, lParam = 100
21:21:25 : wParam : 20, lParam = 0
21:21:25 : MODEL DLL Event : (20, 0)
21:21:26 : Model Dll Msg Not Found(20, 0)
21:21:26 : wParam : 12, lParam = 1
21:21:26 : MODEL DLL Event : (12, 1)
21:21:27 : CLGMobileHttp Class ?Ҹ????.
21:21:27 : CLGMobileHttp Class ?Ҹ?...
21:21:27 : CleanModelDll() : Free Model.dll
21:21:27 : _DetachDLL Call
21:21:27 : _DetachDLL Call End
21:21:27 : FreeLibrary Call
21:21:29 : FreeLibrary Call End
21:21:29 : Step : S/W Upgrade Complete!
21:24:53 : =======Cancel button click : m_nStep(9)
well i think i might have this file in the wrong directory can someone tell me where to put it or just answer my question above?
You can be in recovery or in android. Doesn't matter. The tool will switch the phone into a special mode to flash in both cases.
Well it looks like you already had V9 installed on your phone and you force flashed V9 back onto your phone.
You also typed the wrong bin version "ls670v9_20" instead of "LS670ZV9_20"
Other than that, it looks like the flash completed. What problem(s) were you having?
well thats because this is like my 3rd or 4th time flash it. I probably flashed it correctly the first time with the bin numbers but
Well when i turn phone on i get the lg logo screen then i hear the sprint logo animation after but i cant see it. Then after that i cant see anything. Its as if the screen doesnt work after that. I can do the swipe gesture on the screen when you want to unlock phone and it vibrates and thats it.
I am experiencing the exact same problem. This is on a brand new phone that came with VC, and I am assuming the VC recovery partition as well.
The phone appears to be operating, but nothing appears on the screen. When a button is pressed, the backlight comes on. I can even hear the USB connection sound when I connect it to my computer. I was able to start an ADB session, but I cannot complete the root process if I can't see to go to the market place and install SuperUser.
This occurred when the phone rebooted after being force flashed to V9 with the LG Update Tool. Since the phone was basically useless with no screen, I used the LG Update Tool to go back to VC, but obvioulsy I do not have root yet. Has anyone else experienced this?
how did you go back to vc btw? through updater?
Yes. I launched the LG Updater, then connected the phone via USB, then clicked the red update button on the updater. At least I can use the phone now until I figure out what to do next.
Status
Loki Samhain
