[How To][Links] ROMs/Themes and Kernels ~# Updated 3/20/11 #~
Status
Not open for further replies.
Hey JaeKar,
Just want to pop by and thank you for keeping this thread constantly upto date, you do a great job for the community, thank you very much
Reactions: JaeKar99
ok thanks do i need to delete red version from my sd before using the orange
No you don't have to delete it. According to some posts in jt1134's cwm thread over at xda you can keep both red and orange on your phone and switch between the two. Check out pages 13 andhttp://forum.xda-developers.com/showthread.php?t=942021 14 of this thread:
can u apply nitro dark 2.1 w red cwm or does it have to be done in orange cwm
After installing SC 2.8 CWR red is gone - I now have blue. I will have to reflash the Odin version of red and try that way then reboot into recovery and re-flash the cwm-all file..
Edit: Odin'd back to CWM red (2.5.1.x) - Flashed NitroDark 2.1 vm - booting normal.
All functions appear normal. There are some broken image traces and some odd flickering that is likely associated with the difference in framework.apk for 2.7 and 2.8. Nothing to stop me from continuing to use it.
Will likely leave the update.zip file alone until I need to wake up 3.0.0.8.
To answer the question CWM (red) will install NitroDark 1.2.. I know that orange will install as well.
Reactions: bubbadogg14
I dl 2.8 voodoo so it goes straight 2 red then I jus applied update.zip for orange cwr 2 install it 2 be safe jus wasnt sure before a dl 2.8 that I could have both red n orange I thought I could only have 1 cuz everyone was satin bout 2.8 givin them blue then I realized its cuz they were runnin non voodoo
Boot back into recovery by holding the volume up, volume down, and power buttons until you see the samsung logo flash for the second time, then let go of all three buttons. Wipe cache, wipe dalvik, install just the superclean 2.6 and reboot phone. Many of us have found if you flash the rom, reboot your phone to let the ROM completely load, bot back into recovery and flash whatever theme and whatever else you want then reboot phone you get fewer force close issues. And don't do any nandroid backups. For some reason that's where a lot of people have been running into force close problems. Also when you want to switch themes, unless you know how deep the theme is customized it seems to be a better practice of doing exactly what I described above. Flash the rom separately, reboot phone, boot back to recovery and flash everything else. If the first theme you flashed has deeper customization than the one you want to flash to, remnants of the first one may be left over and cause the fc issues. Flashing just the ROM between wipes away the first theme.
I'm going from SC 2.4 to SC 2.8 and I was going to make a Nandroid backup until I read this. Are we never to make a Nandroid from here on out?
I have only had one nandroid backup I have been able to successfully restore. All others have resulted in a force close loop at boot animation. So I am not doing nandroid backups for now, just too much of a headache.
Reactions: GalaxyNole
Good to know and thanks for all your help today.
When downloading black hole through rom man do you need to do anything first like flash the fascinate. Recovery or just pick what you want and wait for it to do its thing
I am at 29% of 1-30 and all I did was load rom man and pick black hole and do I need to wipe and back up the Rom. I am on stock 2.2 with it detoxted
My fascinate running the 16SC26 is absolutly sick when u add the steelblue 1.2 and rosemary font epic unlock its absolutly smooth glitch free running like a boss thanks again to landshark and DROIDXcon for the help wit that beautiful set up designers are great simply
amazing
Reactions: Landshark
amazing
you're welcome, glad everything worked out for you. did you notice Adrynalyne has now put out superclean version 2.8? The man is a machine and it never ends.
Reactions: T3CH9ICIAN
yes ive seen that but im gonna give it time eventhough its absolutly great work to see feed back more and im super happy with the sc 2.6 right now so not wanting to mess with a good thing for now at least haha
yes i seen that he does great work a true droid machine haha im gonna wait to see feedback and go from there im extreamly happy with the sc2.6 i have now and im not wanting to mess with it its so beautiful all the way around but thats only for now haha
It is a very good idea to back up your current ROM prior to using Blackhole 2.x. I have run this ROM without issue and have attempted to load 3x with mixed results. Because it is pieced together there have been posters who have had pieces omitted.
A nandriod back up is a really good idea because if part of the ROM does not fully download you will have missing apps, or images on your phone.
If you did not get your current ROM backed up - ensure that you have a copy of your base ROM on your sdcard (just in case)... Hope things turn out well.
Status
geochapman
