How to Root
Status
Not open for further replies.
I'm using a mac, and I got hung up on the same part. I just restarted the process from the beginning, and it worked the second time around
I am getting this message:
sh: Can't open /sdcard/com.sh
It will restart your phone now. Anyone have any idea where i am going wrong using Dirrks "almost 1 click solution"
Ran a second time and it worked fine....... thanks guys
I got to the point where it says adb connection will be reset, adb server on desktop and re-login, what do I do next?
Ok finally got it to work after about 5 more tries. Superuser is in the app drawer so I assume it worked. Any way to know for sure?
Just did it for my GFs phone and it was EASY. Got hung up also on the "adb connection will be reset", but after a couple the SU was there. THANKS!
stuck before i even get started...
what am i doing wrong? I downloaded the driver. downloaded the 1-step file, and unzipped it to c:\fascinate with winrar. after I press the any key, the command prompt just goes away. ideas?
Thanks so much!
Thanks so much!
You need to download it again. And unzip it again it looks like your missing the adb.exe file if you used winrar you probably have my old instructions please download the latest one
thanks for the quick reply. ok, redownloaded it twice. extracted it with winrar to c:\fascinate. still getting the same screen. phone is connected with usb debugging checked as well as stay awake. i turned off all auto sync and network connections, just to be safe. also, downloaded the android sdk. don't know if i need that, but i'm a moron so that is probably crucial. sorry guys!
"run part one from the root zip" does that mean just double click on it, or do i have to type something in the command prompt. haven't even seen a command prompt since '90, so please forgive...
go into command prompt
and navigate to the directory that you extracted all the stuff
according to what your telling me u should type this to get there
cd C:\fascinate\
then type dir and post it here
yes just double click on it
Status
masonbiz5
