How to Root
Status
Not open for further replies.
Oh okay. Well you keep looking for a solution and I'll do some research and see if I can find anything that might help you.
Sent from my DROIDX using Tapatalk
Something seems little fishy to me either of the drivers are not installing properly or the other problem with your computer recognizing your phone.
Are you sure that the adb drivers are installed properly?
yes sir i have installed them twice now
but what do you do with them once there installed on the pc ??
plus this method does not say anything about the adb drivers ?
Once you install the drivers attached to the first post you do nothing else.
ADB drivers are installed when you first plug in your phone to the computer. They were not listed because it is a given that they will be there. Though sometimes they do not get installed properly.
Here is what I did to root:
1. Download the 64bit drivers and installed them (I have the 64bit Windows 7 OS)
2. Downloaded the .zip file and unzipped to my desktop using the extract all button.
3. Went to Settings > Applications > Developement > and Enabled Debugging on the phone.
4. Plugged my phone into the computer and waited for it to come up in My Computer.
5. Opened the folder on my desktop and double clicked the START_ROOT file from the extracted folder
6. Waited
7. Rooted.
8. :)
Yea that's what I did for the driod x but its just but working for some reason. I'm going to try on my computer at work I'll write back in a bit.
Swyped via Fascinate.
waiting... hasn't failed yet... waiting, rebooted...BOOM ! theres superuser ! LOL THANK YOU !!!!
6. Waited
7. Rooted.
8. :)
you are the man thank you so much now on to a lagfix !!!
YEA ME TOO, now i cant download anything from the market LOL, i did the cache wipe and rebooted and still nothing... why me...
I can solve that too I think
Do back into Manage Applications. Then go to the Market app listed there. Do clear data and clear cache.
odd they just started downloading now... ok so now onto making a back up where do i start ? on the droid X i just used rom manager... Im guessing its not that easy on the fascinate ?
Sure it is. If you have clockworkmod installed you can do a nandbackup. That would be the easiest way. To do that go into ROM Manager and boot into recovery. There are options within the CWM recovery console to do a nand backup. You can easily restore with that.
If you are going to do the lagfix you will need Clockworkmod anyways.
You can also use TitaniumBackup(I think...never really used it).
ok so i did that and it said failed signture failed and now it shows the trinagle with the ! in it and a android next to it ?
Walk me through it xactly what you did step by step
1. clockwork recovery mod
2. flashclock work, fascinate
3. backup current rom.
4 phone rebooted into recovery then it started going through the settings,
it said signture failed and i didnt know but the home key is the select key so i just rebooted the phone...
In clockwork mod the home key actually just turns the screen blank if you get the home key again spring comes back on. The power key actually selects things in clockwork mod. Did you actually select anything to get the yellow triangle with an !
it says " E:failed to verify whole-file signature
signature verification failed
installation aborted."
ok i did the odin back up on xda forum page and everything seems to be working fine now. thanks for your help !!
All thanks to droiddev
Status
tota
