Huawei p9 build quality?
amr ashraf mostafa
89
Hello p9 fans
I want to know how is the build quality of the hauwei p9?
How scratch resistant is the display glass?
Also how scratch resistant the back glass panel covering the back cameras? Is it made of gorilla glass?
I had p8 but the back glass had few scratches on it,also the metal alloy used in the phone body is not strong, it got scratches and dents easily, so how is that in the new p9?
Triyoung
My assessment is not good. I have had a P9 for less than 1 month. The device was accidentally dropped from a height of less than 2 feet or 1/2 a meter. I expected cosmetic damage, but what happened instead is that the power button AND volume buttons no longer work and the OS is corrupt and will not boot correctly anymore.
You could say my fault for dropping, but the device literally fell LESS than 50 cm, that's less than the fall from your pocket to the ground, and now the device is not only damaged but UNUSABLE. This phone seems to require flawless care.
Would not recommend this device to any but the most careful users
TexasIndia
