dusoccer10
- Jan 30, 2012
- 1,197
- 0
- 0
Re: [Instruction] How to Keep Unlimited Data on Verizon
You can activate the phone with the SIM that was shipped with it. You'll end up reprogramming the SIM to the unlimited plan. Otherwise, you can always take the phone to a VAR and they will activate it for you.
I purchased upgrade on L2 Tiered plan and activated new phone on that line. It was active for about 12 hours. I switched L2 back to original phone no problems.
I went to add new phone to L1 UDP and when swapping sims realized that the new phone has a nano sim and old phone does not, so what are my options?
1. Can I activate new phone on L1 with installed nano sim even though it was upgraded through tiered plan and not lose udp?
2. Should I get a blank nano sim from somewhere else to be safe? If so where?
