LG G3 on ART
Btw, when I switched over to ART, my Window and Transition animation scale were both turned off...is that normal?
Sent from my LGLS990 using AC Forums mobile app
Interesting...I never noticed that because I always turned them off first thing even before switching to ART
so is art the way to go then i have it n bye be lag my g3 is running as smooth as it should of been since day 1 as advertised awesome now
ART does seem to speed up the G3 a lot. .5x animations and scaling and stuff helps to though.
Agreed; changing over to ART definitely improved performance. I'm still tweaking the phone (only had it since Friday) so hopefully more good news to come. I'm also thinking there will be software updates/improvements down the line with Android L on the horizon.
Have to agree. Switched over to ART yesterday, and I can definitely notice a difference.
Sent from my LG G3 using Tapatalk
Yeah I definitely think that will happen too.
Is it possible to change back in the event future issues show up with art?
What about after the L. Update. Then no. Switching back right?
Sent from my Hyperdriven Note 3
What the heck, I'm jumping to art too
After switching to art, did it take awhile to optimize?
Just switched and I'm noticing more delays in the ui than before.
I'm using Aviate launcher if that matters...
Make sure you reboot (power off and back on) after the change
Once you activate it, your device will shut down, restart and then take a few minutes while it "upgrades" all the apps. Then enjoy.
Mav. :cool:
Sent from the future on my Sprint LG G3.
Running ART on my S5 and this will be the first thing I will be changing when I get my G3...of course Nova Prime afterwards. LOL
Could someone who hasn't switched to art on a LG G3 try running the Raceview app? It keeps crashing on load on my G3, but I didn't try it before switching to art....
Thanks
Is there a downside to switching to ART? I just don't know what it is but it sounds like it is a better way to go. Can you switch back easily if it doesn't work?
andiox
