+++ Liquid Smooth Roms 3.2 for Multiple Devices +++
I read somewhere one had moved the alarm clock sounds from 3.0 to 3.2. I like the classic on 3.0 because it's annoying enough to wake me up. Using Root Explorer.....sdcard>liquid 3.0>system>media>audio>alarms>long press classic>extract Now what? Thanx.
I can not seem to play Flash videos ever since I flashed this ROM, which is one of the best I had ever used.
Can someone please help with this? I read throughthe entire thread and someone mentioned it but it was never answered.
Ad as always, thanks for your help!
OK. I flashed a sense rom and got a lock and restored my nandroid backup and still no luck. Although this time I have a gps icon. Just no lock. I also tried gps doctor and gps fix. Help! Please and thank you.
Sent from my HTC ThunderBolt using Tapatalk
Is anyone having problems with Netflix force closing?
Does it run at all or does it force close right when you try and open it?
If the later then uninstall the app and reinstall the app and log in manually. Do NOT restore data for the app from titanium backup or My Backup.
Has anyone experienced low call volume? I have it to the max and it still seems low.
Anyone try this ROM on the droid x? It runs amazing and has phenomenal battery life on my tb and my friend wants me to root her x to make it run better/squeeze more battery out of it.
Anyone?
Anyone?
It should run the same as it does on the TB... but don't you think it would be a better question if you asked it in the Droid X ROM Forum???
Yeah, I thought about that but the place seems dead and the only real rom discussion I see there is about liberty.
super-noob here. Just rooted two days ago and flashed this ROM (loving it so far :D). I only flashed the ROM and have had no problems with it.... so I was wondering what exactly is a kernel, and why/if I would need to flash a kernel.
Explained by novox77 from Android partitions, kernels explained - Android Forums
A kernel is a layer of code that allows the OS and applications to interface with your phone's hardware. The degree in which you can access your phone's hardware features depends on the quality of code in the kernel. The homebrew (rooting) community for HTC has made several kernel code improvements that give us additional features from our hardware that the stock kernel does not. When you flash a custom ROM, you automatically get a kernel. But you can also flash a standalone kernel ROM on top of the existing one, effectively overwriting it. These days, the difference in custom kernels is less about new features and more about alternate configurations. Choosing a custom kernel is basically choosing one that works best with your ROM.
Kernel developers are typically responsible for a small, specific feature in the kernel. For example, netarchy's contribution to custom kernels mainly revolve around removing the framerate restriction that was present in the stock HTC kernel. However, because of the open-source philosophy of all the devs, each kernel "distribution" contains the work of several devs. They openly share new code that they deem will benefit everyone. Basically the best features stay in, and the distributor of the kernel will give credit where credit's due. This means that for any custom kernel you try, you might be using netarchy's FPS fix. It's all a team effort. A new improvement will make it to most if not all of the various kernel distributions in a short amount of time.
What do you guys think about the camera quality? I keep thinking its less so than stock but I am kind of starting to think that is just in my head...
Been running this rom for a few days now and am absolutely loving it. one little question I have though is about the lockscreen ... is it possible to change the text that says "liquid smooth" to something else or to get rid of it?
Im a newbie, had htc tb rooted and running liquid.I tried using the nfl app. Getting a msg its for verizon accounts.Anyone else having this issue or know how to fix it??
Winnie
