- Mar 11, 2014
- 33
- 0
- 0
Lollipop installed and WiFI stops working
I just installed Lollipop 5.0 with Odin. AFAIK there were no problems. But... WiFi refuses to turn on. Bluetooth works, 4G LTE works, but WiFi doesn't. But... if I run FoxFi (might as well see what happens), it does work. That is, I got a hotspot running (a surprise in itself), and was able to connect a Nexus 7 WiFi-only tablet to the hotspot. Unless I'm more confused than usual, this hotspot at least uses the WiFi radios, so that much works. But using WiFi as it's usually done? Nah.
How do I re-enable WiFi?
