Manually Apply 2.0.1 Update WORKING
OK I tried the Droid + Astro. It also failed. Same error.:(
Sounds like you are doing it correctly, the method of downloading the file and/or getting it onto the sdcard is not going to change the error you are seeing. Unless a technical person has the same problem and can provide insight, you really just have to wait the day or 2 to get the update from verizon and see if that does the trick. It's my understanding that the update that manually install and the one they send is indeed the exact same, but you'll only know once u get it from them.
It might be doing some verification that the current build is authentic and in the state that it would expect, and bags if it doesnt find that. If that is the case and you have not tampered with the OS then you'll probably need technical assistance from verizon or a new phone.
Good luck
Still no Notifications if someone writes on your wall or something, but now I'm receiving notifications if someone tags me in a post or "pokes" me. Weird...
i don't think the current facebook app has a setting to alert you for wall posts or comments, so it's not that the app isn't working right, it's that the feature just isn't in it.
I got used to the new lock screen.
Along with what everyone else is noticing.
-I also like how the Power and Media widegets are now Blackish/Gray
-For some weird reason GPS now works better, when using BW and WWD I would get LA (regardless of wether I was in Burbank or Northridge). Now I get the actual city name.
-Even the GDE transitions using cube look better.
I am happy with this update.
Man. What a hassle ~ :(
That is probably what it is, thanks for clarifying that!
Finally got some free time at work to apply this update. Coming from bb for 3 years and the storm most recently I have applied quite a few operating systems. This install on the droid was ridiculously easy and only took about 10 minutes to complete. Phone seems to running pretty smooth not as many transitional hiccups. Especially glad they got the choppiness out of pulling down the notification tray. I guess the new lock screen is ok, liked the other one better but not a big deal.
I read somewhere that Verizons update will not work if you have 40% or less battery life left, and would assume the manual one is the same way. This might be causing some people issues,
PS. Same positive reports as everyone else, can't wait for the next one!!!
I wish my GPS said LA...it's COLD here (Minnesota) :)
My update went fine, and I have the 40/09 build date.
man this is really starting to piss me off
i've got some dolt on another forum that keeps telling me over and over, "no, rename it to just update and it will work" :mad:
Have you tried getting a fresh zip file? Maybe something got messed up in the transfer. BTW, I used PC first, renamed, then usb to memory card.
I think you just have to wait until verizons auto update comes through and see if that fixes. You're not missing that much in the update, it's not like its a new toy after it.
You'd also think that out of the people that already got verizons auto, u might have heard in forums/google about problems, but I haven't heard any. Chances are the auto update will work.
yeah i'm not really concerned about getting the update. what i am concerned about is that there's something franked up with my phone that will prevent me from installing other mods and such. that's half the fun of having an android phone.
Installed with no issues using Ubuntu so much easier than bb updates and leaks. Not to mention the hybrids.
creatorxd56
