[MEGATHREAD] What is app 10xxx?
morpheusoptic
Unknown app "10252"
I was recently looking at my data usage in the settings menu and noticed an app I have never seen before. Does anyone know what the one that says "10252" is? I have no app by that specific name and there is no way to go to the app settings by clicking on it from the usage menu.
I looked through all my apps in the app manager and it is not listed in any slide eg. Running, downloaded or All. If anyone knows what this is I would appreciate it.
The only data it uses is background data, which I have subsequently turned off.
Thanks in advance.
Re: what is this
Welcome to the forums. Those 10xxx processes usually refer to apps that were recently uninstalled and they show the data they used on the actual cycle while installed. They should disappear in your next data cycle.
Samsung s6 help please
Some app called is draining my battery 10464,10700,10466 Will you help me with the virus?
Re: Samsung s6 help please
Welcome to the forums. Those 10xxx numbers usually refer to apps that were uninstalled recently? Is this your case? Full charge your phone and see if they still show up on your next battery cycle.
Unknown app/process(10106) draining battery.
This particular app is draining my phone battery so much. What is it? And what should i do? This 10106 is not even active in background and has zero active usage time but it still consumed 13 percentage of my phone battery what should I do?
Re: Unknown app/process(10106) draining battery.
Have you recently uninstalled an app?
Try charging fully and see whether that fixes it.
Tell us if no go.
On my s8 ( nougat 7 ) UID no. 10106 refers to an app called CNN for edge panel. I would say usage would be more along the lines of your internet connection even though it's running background free. You check app settings. Force stop app see if it makes a deference. You could also limit data usage as well.
Random app called 10047 on wifi usage
I was looking at my wifi usage on my samsung 9+ and I have a random app called 10047 that has used 104B in the background, anyone have any idea what that is?
Re: Random app called 10047 on wifi usage
Hi, welcome to Android Forums
I'd like to recommend creating a account so me or other members can assist you, as guest have limitations in replying here and if we need further Information to communicate with you.
I'll provide a link to register, please come back to your post so we can further assist you . Thank you
https://forums.androidcentral.com/showthread.php?t=409154
Welcome to the forums. That WiFi usage probably refers to an app that was removed in that cycle. Had you recently uninstalled any app?
I uninstalled android auto, and reinstalled chrome and google I'm sure it's probably nothing but i can't find anything online about it and would like to be sure, i also already have a slot for apps i deleted but i guess it could be left over from that as well.
Probably because you uninstall that app , looks like nothing to worry about
Thanks for registering. Usually those 10xxx refer to apps that were already uninstalled. Nothing to worry about, it should disappear on your next cycle, after September 5th.
Oh wait, today is the 5th :) Check back tomorrow for the new cycle and see if it still there.
10384 and 10386 apps
These apps are using data but are not visible in Apps section.
I have restricted them now however seem strange please see below imageScreenshot_20200206-135826.jpeg
What are these applications?
Hello, I was checking the data consumption of my cell phone, and I found eighteen "Apps" that consume data, none have a name, only have numbers.
and they are these:
10181 consumption 660 MB
10177 consumption 3080 MB
10186 consumption 149 MB
10163 consumption 126 MB
10166 consumption 24.04 MB
10192 consumption 17.17 MB
10171 consumption 8.16 MB
10173 consumption 7.25 MB
10167 consumption 7.04 MB
10175 consumption 2.80 MB
10174 consumption 1.90 MB
10172 consumption 0.95 MB
10193 consumption 519 KB
10183 consumption 291 KB
10191 consumption 178 KB
10190 consumption 132 KB
10187 consumption 102 KB
10188 consumption 21.81 KB
What is this about? or are they some kind of malware? I would very much appreciate your responses, thank you.
posdt: Sorry if I don't express myself or write well my English is bad :(
Re: What are these applications?
Welcome to Android Central! Apps in that list that start with "10xxx" are typically apps you recently deleted -- it's showing you the last amount of mobile or wi-fi data those apps used before you deleted them.
Please register on this forum, which will allow you to engage in discussion more easily, as well as post images. https://forums.androidcentral.com/ask-question/409154-join-android-central-community.html
rjagathe
