If anyone hasn't considered sending you bolt back to verizon under the trade-in program you really should while verizon is being generous.
well 4months on the market for the thunderbolt vs 2 weeks for the charge so you do the math. Plus i wouldnt say one is better than the other because both are strong where the other is week. what it all boils down to is with the samsung, it doesn't power cycle and the screen is worlds better. I mean come one AMOLED versus WXGA LCD. to be fair though the tbolt does have more ram. The samsung has better battery life and the tbolt has sense. Both phone brands update regularily (at the about the same interval). Basically the reason why i had no problem switch was the better screen, more stable and better battery life.
They reafirmed what i was told last week, they sai that this MR2 update is being built to fix the battery life issue.
I wouldn't count on the update fixing the reboots. I called Tier 2 support again today to inquire about this update. They reafirmed what i was told last week, they sai that this MR2 update is being built to fix the battery life issue. They also said that HTC wants verizon to collect serial number of power cycling devices to determine if there is a bad batch or batch's. HTC will only work on an update to address the power cycle issue once they have collected enough info which could take months to accomplish. Basically put, the power cycle issue will be patched later this year. Until then if you managed to make your phone stop rebooting then consider yourself lucky. Two minutes after i was told this, i sealed the envelope on the trade-in package that contained my thunderbolt and handed to the mail clerk. The concelation prize for my troubled is the nice $240 gift card that will be mailed to me. If anyone hasn't considered sending you bolt back to verizon under the trade-in program you really should while verizon is being generous.
I gave up after looking through 12 pages of this thread...but does anyone know if after updating to this fix, will I still be able to receive OTA updates via VZW/HTC? Any answers appreciated...
I wouldn't count on the update fixing the reboots. I called Tier 2 support again today to inquire about this update. They reafirmed what i was told last week, they sai that this MR2 update is being built to fix the battery life issue. They also said that HTC wants verizon to collect serial number of power cycling devices to determine if there is a bad batch or batch's. HTC will only work on an update to address the power cycle issue once they have collected enough info which could take months to accomplish. Basically put, the power cycle issue will be patched later this year..
I applied the MR2 update yesterday and had my first random reboot about 3 hours ago.
