Note 10+ N975U carrier universal and unlocked models firmware.
Do a factory reset, then try to odin again , also make sure your usb port is not 3.0 also try a different usb cable.
Thank you for quick response.
In window 10, I have tried USB port on back of pc. Still stuck on Odin for long time and won't flash. It's fine when flashing U1 firmware.
Switch to Window 7, USB port on back of pc. Still stuck on Odin for like 2 or 3 seconds, then started flashing ATT firmware.
After setup on note 10 plus with ATT sim card, VoLTE and Wifi calling work.
So you get it to work is my understanding correct?
Hey are there any recent att firmware updates that I could get a link for? Last one I got was from August I believe. Thanks guys!
Pick up Note 10 plus 5G SM-N976V and trying to flash to unlocked firmware or ATT. Having isses. Re partition error. Ive done some reading and an old post said the Verizon model connot be flashed? Current build number is SP1A.210812.016.N976VVRS8HWG1. If it can be flashed does anyone have a link to the correct firmware...
Usually Ruben gets those , otherwise flash Tmobile firmware.
You can flash TMB through Frija but I would go to the unlock model using Odin Patch B
CrazyParis
