Note 3 KitKat fix Asap
OK hold up let's go back so my problem with my phone is now after using odin to flash the MJ5.tar to (ap, bl, cp) I was to then do the next part which is use heimdall to do whatever cuz it confuses me n that's where I'm stuck pretty much.
Also after I flashed the MJ5 I couldn't boot my phone like there's no boot.img on N3 or else it would boot up. N I could do a ota to NB4.
you need to follow the directions. You flash those files with odin.. then you boot back into odin mode and heimdall. You're not finished after using odin. FOLLOW ALL THE DIRECTIONS.
I did I just checked again I go through all and every step
Yes. Follow every direction. Boot into odin mode.. load the files with odin. Boot back into odin mode and to the heimdall part. Boot into recovery and load the SEC file and then boot back into recovery and load the 248 or water it's called then reboot. Done. It's not that hard
OK then there must be something wrong with my phone because u said reboot n I can't reboot anything with out a boot.img flashed on the phone n I don't have a Rom on it
Jesus dude. Volume down+home+power puts you in odin mode.
Volume up+home+power puts you in recovery.
I know that but it's how u are phrasing the directions like volume down isn't odin mode it's DOWNLOAD MODE. Up is RECOVERY MODE. Lol didn't mean for u to get upset cuz I'm the one pissed my phone is like bricked almost
Ok dude. I'm sure someone else can help you out. Check xda, I've tried and I don't know how you're messing the MJ5 restore up. And yes download mode is the same as odin mode. Good luck
Thanks but now I'm bricked with ur help ....great..
You're right I bricked your phone with a method I've done 4 times. Guess what though. . My phone works just fine and I'm running KK. So I guess I don't know what I'm doing.
Yes but then I'm kind of confused after that with the heimdall
Follow the directions. You have to install those 2 files so heimdall will open.. then you open the drivers folder and follow the directions for that.. then you open the heimdall frontend and follow those directions.
Yo man I wanna say thanks tho even though I'm dying over here
You're just getting ahead of yourself. Everything is written out in the directions. Go slow. I know you want your phone to work.. but if you keep messing up you're getting no where. Read them slow and go one step at a time
I have stock rom is there a way I can just go back like back to stock and start over
Update I got the heimdall to flash the system.img next
Phone is back up and running I now just have to wait about a day or so until I can update to NB4 via ota I'm going to see if I can use Kies first
OK so dude u r amazing it worked 1000,000,000,000,000%%%%%%%% THANKS BRO
alejandro109322
