Note 3 KitKat fix Asap
i keep getn a error saying error 7 in temp/sideload.zip then it says something eslelse in red but i cant read it cuz its to fast
Are you referring to the method I posted? Or the other one from XDA? I've not done the other method, I have done the one above that I posted from XDA. Hopefully someone with more experience with the other method will chime in.
I didn't use the side load option. I did option A that wiped the phone.
I'm trying to start over I have downloaded the stock android software for my N3 and now I am trying to flash it via odin and it's not working I keep getn a red msg "[sbl1]Fused 2 > Binary 1]
Do this http://forum.xda-developers.com/showthread.php?t=2559715
[12/29] Restore for MJ5 --Doesn't trip Knox and optionally provides root--
Then this http://forum.xda-developers.com/showthread.php?t=2701062
[3/31] Fix for KitKat Update Failing - Without ROOTING
It's says put everything except the system.img on sd card where is the system.img located
I think I found it under patch but what do I do with it it said on the X da forum not to put it on sd card so where should I put it
You're gonna use it in heimdall. Read the directions.
It says MI9_ will be used in the slot on meindall not system.img
My heimdall is setup like the screen shots but I get
Error: failed to send data !releasing device interface
Detected I/O error[ 87] The parameter is incorrect
What exactly am I flashing in the cmd prompt (heimdall flash --............?????????
I don't know what you're doing. I didn't use one cmd prompt. Are you doing those two links I posted?
OK hold up let's go back so my problem with my phone is now after using odin to flash the MJ5.tar to (ap, bl, cp) I was to then do the next part which is use heimdall to do whatever cuz it confuses me n that's where I'm stuck pretty much.
Also after I flashed the MJ5 I couldn't boot my phone like there's no boot.img on N3 or else it would boot up. N I could do a ota to NB4.
Jayarealways
