[Odin] Froyo leaked packaged custom ROMs w/root and clockwork **UPDATED**3/25
yea its a first for me jsut did it again and got maybe 5.5 mb and itsd just stops no reason no notification wont resume wont finish out nothing ? is it me ?
This is what ur saying for me to grab just so im correctly fallowing you [NO DATA WIPE MAY CAUSE FC IF COMING FROM ECLAIR] Super Clean version 2.8 - EB01/EB16 Froyo leak root+Froyo Clockworkmod w/Nonvoodoo eb16 kernel w/ dummy tether module with MALWARE protectionTHIS VERSION DOES NOT WIPE DATA OR CACHE (TESTED by Standupdad Please thank him)RIGHT CLICK AND SELECT EXTRACT HERE THE .rar file AFTER DOWNLOADING AND BEFORE USING(How to extract in post #2) -->EB16SC28x_DXC.tar
yes sir
Am I missing something
Before flashing my phone with the Super Clean 2.8 I was able to use my Blueant S4 handsfree speakerphone in the car with no problems. I just had to say "phone commands" and it would open Nuance or Vlingo etc..
Since I flashed my phone, when I say "phone commands" the blueant responds,
"This feature is not supported on the connected phone."
Does Froyo not support Voice Commands? I had no problem before flashing to SC 2.8 now my voice commands over bluetooth doesn't work..
The whole point of upgrading to Froyo was to have the luxury of not having to use a thirdparty app to dial people with handsfree. Not only am I having to use an app, but I can't even trigger it with voice now..
well you are using a custom froyo so its not going to have all the features you want off the bat a whole bunch of stuff has been removed, either flash stock froyo or
go to Adrynalynes (he developed the rom) thread
http://forum.androidcentral.com/ver...s-hacks/53810-rom-superclean-2-8-updated.html
i think there is a patch for nuance that will fix things,,or ask him for a patch to fix the problem
Is there anyone out there with a faster connection that can Download and mirror EB16SC28x_DXC.tar for T3CH9ICIAN
my work connection is going to take over 40 mins to get this done
Reactions: T3CH9ICIAN
appreciate all the trouble your going threw DROIDXcon this is a first for me and sounding like uncommon to you thanks for any and all help ur providing
just doing the best i can, i am done at work and want to leave but my connection is so slow here at work.:-\
EDIT: i think something is wrong with megaupload because its locking up for me aswell...ill go home and try it from dropbox
Thank you thank you thank you
It's not that it was a big deal to press the home key but a fix for it is awesome.
Has anyone found a fix for the voice mail key in the dialer always bringing up Google Voice? Like the above it's not a huge issue because long pressing the 1 key connects to *86
Check out the themes thread:
http://forum.androidcentral.com/ver...ks-roms-themes-kernels-updated-3-06-11-a.html
I know the Nitro Dark theme has options for the Verizon voice mail dialer and the Google voice mail dialer. If you don't want the theme the developer has zip files for just the dialer by itself.
got ya ummm would i b able to flash EB16SC26 over my system threw odin like an almost reset or will that cause more problems then fix it
whats data will all b wiped out ? im not fallowing real well sorry phoneless is messing with me a bit its my first failure so kinda kickin myself knew it would happen but still sucks
Khalequzzaman
