[Odin] Froyo leaked packaged custom ROMs w/root and clockwork **UPDATED**3/25
Really thats still not resolved
Nah, I think that's only the second time I've posted an answer before you. Now if I could just figure out why I can't get the 3D app drawer to work in LP.
Sent from my SCH-I400 using Tapatalk
Thanks and question about Update.zip
Just leave it where it is. If you want to flash anything by itself such as a theme, different ROM, different kernel, or add-on you will do that through clockworkmod recovery, and update.zip is your key to get into clockworkmod recovery
I cannot find update.zip on my SD card. I entered recovery mode (vol up+down+powerbutton,,,hold till you see samsung flash twice then let go...then go to apply sdcard:update.zip, press the home key and it will lead you into clockwork) but it did not find it.
What is the safest way to get it on the SD card?
Thank you for all your work for us novices. I've learned SO much.
Safest way to get update.zip on the sd card is to download it directly there if your pc allows you to do that or save it to your pc then drag/drop it to your sd card. With your phone in debugging mode, plug your phone into your pc with the usb cord that came with your phone, pull down the notification bar, click on usb connected, click on the gray "connect usb storage" bar, click OK. An autoplay window should pop up on your pc, click "open folder to view files." The window that opens is the root or base of your sd card, this is where the update.zip file needs to go.
Yes there is a fix for that. Long press on the contacts icon, choose change shortcut, choose phone. Long press on that phone icon, choose change shortcut, choose contacts. Now you should be able to get out of the contacts page by hitting the back soft key.
Thank you thank you thank you
It's not that it was a big deal to press the home key but a fix for it is awesome.
Has anyone found a fix for the voice mail key in the dialer always bringing up Google Voice? Like the above it's not a huge issue because long pressing the 1 key connects to *86
my voice mail key goes striaght to voice mail since i flashed the touch of blue theme
Anti-Virus flagged of FascinateRoot_v02: "Exploit:Unix/Lotoor"
Windows Essentials flags the file "FascinateRoot_v02" as having a serious threat of "Exploit:Unix/Lotoor" within. Anyone else see this?
Thanks
Thats exactly the way rooting works you personally unleash a trojan into your system and gain access to your phone
Thanks
Its only dangerous when someone else is the one using the exploit without your knowledge.
im needing some help to anyone out there im running 2.2 EB16SC26 with steel blue i grabed an market app not set cpu but another close to it after that phone lost data froze up then when i went to reboot im stuck on the blue reboot screen when i remove battery and restart same thing soft button reboot phone goes to a small white triangle with an ! point and droid im stuck i was able to get the other app off that messed my phoen up but still stuck in android system recovery blue and wont go past the triangle
flash EB16SC28x_DXC.tar
OK, Thanks..
So, I tried twice to walk through the rooting process. It never comes out of the shell. I waited 15 mins the first time, 10 mins the second. Any suggestions. (Besides locate the box and return it to the seller, cause I'm too dumb to own one!) ;-)
C:\FascinateRoot_v02>adb devices
List of devices attached
I500eea3ab54 device
C:\FascinateRoot_v02>adb push rage.bin /data/local/tmp/rage.bin
19 KB/s (5392 bytes in 0.265s)
C:\FascinateRoot_v02>adb shell
$ cd /data/local/tmp
cd /data/local/tmp
$ chmod 0755 rage.bin
chmod 0755 rage.bin
$ ./rage.bin
./rage.bin
[*] CVE-2010-EASY Android local root exploit (C) 2010 by 743C
[*] checking NPROC limit ...
[+] RLIMIT_NPROC={3712, 3712}
[*] Searching for adb ...
[+] Found adb as PID 3006
[*] Spawning children. Dont type anything and wait for reset!
[*] If you like what we are doing you can send us PayPal money to
[*] 7-4-3-C@web.de so we can compensate time, effort and HW costs.
[*] If you are a company and feel like you profit from our work,
[*] we also accept donations > 1000 USD!
[*] adb connection will be reset. restart adb server on desktop and re-login.
OK, Thanks..
Pull out the battery, and try again after the phone reboots make sure you unlock it.....wait longer , some people have taken up to an hour , i dont know why sometimes it just takes longer
After each ROM I apply, I do a *228 option 2. It seems to help but I'm not 100% sure it is needed.
I have a question about this. I recently (3/3) loaded the EB01 leak + clockwork chioce and I'm glad I took the plunge. however, battery has taken a hit but I realized my screen brightness was set really high so fixed that. Then today, three days on the new ROM, I stopped getting phone calls. All of a sudden I'd get an icon for voice mail but no call had come through and the call log was empty. When I called my friend back (yes, I could access voice mail and call out) he said the phone rang for like 8-9 times then voice mail picked up so it wasn't as if the phone was off and went directly to voice mail. I did a battery pull and then *228 option 1... I was surprised the process lasted barely 2 seconds and said success. Usually this takes a minute or so. Also tried *22899 and *228 option 2 both with same super quick "activation". Now, my phone works again and all but I'm still concerned that this *228 is busted with this ROM?
the rom does not have much to do with the radio so it should be fine, i wouldnt worry as long as you are back up and running
aight ive found it im gonna try and DL it again for some reason first 2 times it stoped and would not finish at about 90 percent
Edie Raleigh
