[Odin] Froyo leaked packaged custom ROMs w/root and clockwork **UPDATED**3/25
Hey all, I thought I read somewhere that SC 2.9.2 was packaged with EC10? I just flashed it and while I see that it's updated to 2.9.2, my About Phone still lists EB01 in both Baseband and Build #.
Do I need to use Odin to flash that on as well? I'd like to use it. Thanks!
eta: Yeah, it's in the title of the 2.9.2 file. What's up with this?
Shark, You mentioned that you dont recomend voodoo for newbies but since my phone is working should I leave it alone or do you recommend going back to no-voodoo?
If it's working, you can leave it alone for now. Just make sure you read every single word in Gunnermike53's voodoo thread. Study it and burn it into your brain that you cannot flash anything nonvoodoo over voodoo. Going from voodoo to nonvoodoo involves first disabling lag fix in cwm. Remember nonvoodoo over voodoo = doodoo
Gunnermike53''s Voodoo Thread Here
It is packaged with the EC10 kernel, but everything else is still EB01 which is why you are still seeing that in baseband, build, and kernel version.
I was on SC2.9.1nv w/ EC10 patch. I want to try the DL09 modem which I used to have luck with way back a whole couple of weeks ago,lol, but all I seem to find is a DL09 tar. file. which would bring me back to total stock right, Bing etc.?
I thought there was a link somewhere for the modem only and it would be flashed through Odin? Not from the SD Card through recovery?
Where did you find that DL09 tar file? The modem should be in a tar file since it is flashed in ODIN. See how many MB the file is. A full ROM should be 130 MB or so. If it's much smaller, that is the modem and the correct thing to flash in ODIN
Reactions: mm247
Good question. I've downloaded so much stuff I can't remember where I get things.However it was the whole enchalada cause it took me back to stock. I then had to go to 2.9 from the OP ( presuming it had the wipe for Eclair and it looked like the 2.9.2 wipe ver. had been pulled) and then to 2.9.2 non-wipe to get back up to date with SC. I did find DL09 modem only (15.5mb) though on Adrynalne's SC thread a few posts from the top.
I may stay with 2.9.2 stand alone for a few days and see how battery life goes before trying the DL09 modem, we'll see. Thanks for your help Landshark, Droxi, Adryn etc. It sure makes a noobie brave when experts have your back.
Reactions: Landshark
I posted this in the main Fascinate forum but someone suggested I re-post here.
I used ODIN and the instructions in this thread. I installed EC16SC29.DXC.tar. I have flashed nothing else, added no themes.
After being inspired by Jampot's thread I decided to take the plunge and go for Froyo. I had never rooted my phone before. The instructions were great and the rooting, Titanium backup, installation of super clean Froyo, and restore of the apps I wanted went off without a hitch. I did it on Friday afternoon.
Overall I like Froyo and it does seem like it moves faster than before. But I'm noticing some other problems and perhaps someone can point me in the right direction.
1. The volume rocker no longer will silence the ringer on my phone..my only option is to reject the call. I like the rocker silencer since I can hit it while the phone is in my pocket.. I can't figure out how to get it back.
2. I would like to be able to change the 3 fixed buttons at the bottom.. I don't like the grey color of the phone, app, and browser buttons.. I preferred the TouchWiz style where there were 4 color buttons that included messaging as well. I'm not saying I want Touchwiz back..maybe I do.. but can someone make a reccomendation? I know there are probably tons of choices out there. I don't want anything wild & crazy..but those grey buttons are kind of lame. ALREADY GOT SOME HELP ON THIS, WILL TRY LAUNCHER PRO.
3. My phone is freezing up a lot. I have had to re-boot several times since I installed Froyo.. it was very rare that I would need to re-boot before. On Saturday someone called me and left a voicemail... my phone was with me but it didn't ring or give me any indication I had a message so I was unaware I had a call. Later that person came to my house and asked if I got his message.. so I picked up the phone... no indication. I called *86.. and the dialpad appeared along with the green phone indicator in the upper left corner letting me know a call was in progress, but nothing happened and the dial pad would not let me end the call. Other functions were working..I could use the browser OK. So I had to re-boot, and then I was able to retrieve the message from voice mail. There was still nothing in the call log though. Not a good sign.. I don't like to miss calls.
This morning, after being plugged into the charger all night, the screen was on and it told me it was fully charged. I unplugged the phone and it was completely frozen with the screen on to the pattern lock. I had to remove the battery in order to restart it.
4. Battery life appears to be a bit worse now. My phone actually died on Saturday night for the first time ever. I suppose I did use it a bit more than normal because I was playing with some new features. But it just seems to drain the battery faster than before.
Thanks for any suggestions you might have!
Flash EC10SC292x_DXC.tar
Sent from my SCH-I500 using Tapatalk
Reactions: SEAKevin
HAHAHAHA "nonvoodoo over voodoo = doodoo" totally stealing that line
Hey DXC, where can i find the EC16SC29_DXC.tar file at? the link on the first post for it points to hte EB16SC29_DXC.tar one megauploads. also, isn't EC10 and EC16 the same?
thanks
Reactions: DroidXcon
Crap...so I chose the wrong one to flash in the first place!
I see in the instructions it says EC10 will not wipe data.. does that mean I don't need to back up anything before I flash it and then restore my settings/files/apps after it's flashed?
thanks
Super Clean version 2.9 - EB01/EC16 Froyo leak root+Froyo Clockworkmodwith MALWARE protection
RIGHT CLICK AND SELECT EXTRACT HERE THE .rar file AFTER DOWNLOADING AND BEFORE USING(How to extract in post #2) -->EC16SC29_DXC.tar
Super Clean version 2.9.2 - EB01/EC10 Froyo leak root+Froyo Clockworkmodwith MALWARE protection
RIGHT CLICK AND SELECT EXTRACT HERE THE .rar file AFTER DOWNLOADING AND BEFORE USING(How to extract in post #2) -->Pulled
WARNING: NO DATA WIPE MAY CAUSE FC IF COMING FROM ECLAIR, FULL WIPE IS RECOMMENDED
Super Clean version 2.9.2 - EB01/EC10 Froyo leak root+Froyo Clockworkmod with MALWARE protection THIS VERSION DOES NOT WIPE DATA (TESTED by Standupdad Please thank him)
RIGHT CLICK AND SELECT EXTRACT HERE THE .rar file AFTER DOWNLOADING AND BEFORE USING(How to extract in post #2) -->EC10SC292x_DXC.tar
i dont understand, i checked both and they both lead to their respected downloads
EB16 and EC10 are not the same they are different kernels from different builds
Edit: ok i see the problem
the will only work if you are already on a froyo build, if you are coming from eclair you need to wipe data.
if you are already on a froyo build then you can use it and it will update you without losing data
Reactions: SEAKevin
so if i'm running EB16SC29_DXC.tar then i can flash EC10SC292x_DXC.tar via odin and all the apps i restored from backup will still be there?
ajr81
